Crap, my bad for ignoring these forums for a while. It was hidden behind the glove box from what I remember. So you're most likely going to have to remove that so you can get 100% behind that area. It was a large 4 pin relay (I believe there were two near each other) tucked up in there. Two larger wires were red and blue? I'm colorblind too, so I'm probably imagining colors lol. Check that to see if it's powering on.
Though I don't think that's it, considering you've got a good side working. My next best guess is to check the harness going through the door for any cracks for frays. I would say your switch in general could be bad, but I'm sure you figured out it's not the issue by testing the switch on that physical side. I want to say that without a working master switch, all of the windows or some will not work. I feel like I came across that in the midst of trying to figure out my window situation.
Considering it's 1:20AM here, I'll see about getting a photo up if I can remember. I'll have to remove the glovebox since I put it on after fixing the job.
