Thread: What next to test for power windows?
Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
  1. #1 Re: What next to test for power windows?
    Jun 2014
    Maryland, USA
    Keep in mind the switch reverses voltage. I haven't tried testing at the main switch before..I typically go to the motor plug. That way you'll either be expecting +12V or -12V depending on which way you are heading
    I tested the output wires to the motor from the switch. Then being curious tested the positive wire to the physical switch from the boot side & I think it was around 0.23 volts.
    Car was running, battery is fine, fuse was in and a new fuse at that. I know nothing about electronics in a car, though it doesn't sound normal to have that little going into a car window. If there was a break in the wire I would assume my meter would read zero.
  2. #2 Re: What next to test for power windows?
    Ok.. so you aren't getting power to the main switch.. which is an issue. You did get harnesses from the same year car, right? And the big power wire did line up in the connector and neither wire pushed back out? It's a pain..but it's the little things. Other than that..there's like a relay in or controlled by the bcm (body control) that gives the windows power. I'd check the in and out of that relay as well.
  3. #3 Re: What next to test for power windows?
    Jun 2014
    Maryland, USA
    Where would that relay be? I thought that too but couldn't find anything over the interwebs.
  4. #4 Re: What next to test for power windows?
    I'd really have to look up the schematic for you.
  5. #5 Re: What next to test for power windows?
    Jun 2014
    Maryland, USA
    Have had time lately to figure out what's going on. There is no power to the fuse, so I have to trace the wires and figure what's going on. Also, I found an adapter not connected to anything and looks like someone else did the wiring to it. And it appears to have a speaker wire going to it?
    I'll let you have a look and hopefully you know what it is, or have an idea.
    Btw, that was found behind the glovebox.
  6. #6 Re: What next to test for power windows?
    SE Level Member Burley117's Avatar
    Nov 2011
    Kalamazoo, MI
    Did you every find a solution to your problem here? I'm having similar symptons and curious what you ended up doing.
    06 Grand Prix, 01 Grand Prix GT, 98 Grand Prix GT, 98 GrandPrix GTP
  7. #7 Re: What next to test for power windows?
    Jun 2014
    Maryland, USA
    Quote Originally Posted by Burley117 View Post
    What my issue was a relay hidden in the dash, it took some digging and probing around to find it. If you need more information about which relay it was, I'd be glad to do what I can to help!
  8. #8 Re: What next to test for power windows?
    Nov 2011
    Kalamazoo, MI
    Quote Originally Posted by JayHerlth View Post
    Any advice here?
  9. #9 Re: What next to test for power windows?
    Jun 2014
    Maryland, USA
    Any advice here?
    Crap, my bad for ignoring these forums for a while. It was hidden behind the glove box from what I remember. So you're most likely going to have to remove that so you can get 100% behind that area. It was a large 4 pin relay (I believe there were two near each other) tucked up in there. Two larger wires were red and blue? I'm colorblind too, so I'm probably imagining colors lol. Check that to see if it's powering on.
    Though I don't think that's it, considering you've got a good side working. My next best guess is to check the harness going through the door for any cracks for frays. I would say your switch in general could be bad, but I'm sure you figured out it's not the issue by testing the switch on that physical side. I want to say that without a working master switch, all of the windows or some will not work. I feel like I came across that in the midst of trying to figure out my window situation.
    Considering it's 1:20AM here, I'll see about getting a photo up if I can remember. I'll have to remove the glovebox since I put it on after fixing the job.
  10. #10 Re: What next to test for power windows?
    Nov 2011
    Kalamazoo, MI
    I would greatly appreciate some guidance on finding this relay! After testing I found the voltage on my "good" (drivers) side to be around 8.7v...on the "bad" (passengers) side is in the millivolts.
  1. Power windows don't go down
    By schwarry in forum Shops and Community Heroes
    Last Post: 01-03-2013, 01:02 AM
  2. Windows Have No Power
    By Solid Steel in forum Audio, Security & Visual Electronics
    Last Post: 04-16-2012, 02:03 PM
  3. windows go up/down with no power....
    By urnotaslave23 in forum General Tech Discussion
    Last Post: 05-29-2011, 06:49 PM
  4. Power Windows
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 03-12-2008, 08:51 PM
  5. Power Windows
    By stlmo_gtp in forum Off Topic Discussion
    Last Post: 03-08-2008, 03:58 AM
