Thread: Power windows don't go down
Results 1 to 12 of 12
  1. #1 Power windows don't go down
    Dec 2012
    Cincinnati, Oh.
    Well this is my first post....
    I have a 99 GTP. Only the drivers window will go down. I tried the lock out button up and down. The windows don't work off the drivers control or any of the other door controls. Any ideas?
  2. #2 Re: Power windows don't go down
    sounds like the master window switch is dying on you.
    ebay or junk yards, or you may find new switches on e bay or amazon.
  3. #3 Re: Power windows don't go down
    2 or 4 door? Did you just get the car?
  4. #4 Re: Power windows don't go down
    Dec 2012
    Cincinnati, Oh.
    Its a 4-door. Do all of the switches connect through the switch on the drivers door? I just got it a few weeks ago.
  5. #5 Re: Power windows don't go down
    Did you just get the car? All the regulators could be bad
  6. #6 Re: Power windows don't go down
    Dec 2012
    Cincinnati, Oh.
    I just got it a few weeks ago. I can test the switches on the drivers door and the others. Test for current at one door, and cross the wires there, if there is current. I think the doors are just two-wire connectors. If it goes down, its either the main switch, the relay, or the switches on the doors. If I'm getting no current at one of the rear windows, then maybe its the lock out switch.
  7. #7 Re: Power windows don't go down
    when my master switch went bad, only the master would work all the windows, all the switch's on the other 3 doors went dead.
    cause was the window lock part of the master switch. aka drivers side door controls.
    you could run power to the window regulator motors, see if they move. if they work, then is a switch.
  8. #8 Re: Power windows don't go down
    Dec 2012
    Cincinnati, Oh.
    Ok...I crossed the lock out switch and got the windows to work. Thats good. 3 regulators didnt sound too good! Do I have to buy the whole unit for the drivers door?
  9. #9 Re: Power windows don't go down
    all 5 switches are one unit for the master.
  10. #10 Re: Power windows don't go down
    Dec 2012
    Cincinnati, Oh.
    Thanks guys. I'll get some pics up when I get it done. Oil pan tomorrow!
  11. #11 Re: Power windows don't go down
    Quote Originally Posted by schwarry View Post
    thats a much bigger project. make sure its not the valve covers or rear crank seal first.
  12. #12 Re: Power windows don't go down
    Dec 2012
    Cincinnati, Oh.
    it was bottomed out on the pan, and it's leaving spots of oil on the left and right side of the pan. The pan is dented, and my theory is the pan being hit broke the gasket loose on both sides...and all the way around. I got a new pan, and breaking out the cherry picker tomorrow.
  1. Windows Have No Power
    By Solid Steel in forum Audio, Security & Visual Electronics
    Last Post: 04-16-2012, 02:03 PM
  2. windows go up/down with no power....
    By urnotaslave23 in forum General Tech Discussion
    Last Post: 05-29-2011, 06:49 PM
  3. Power Windows Help Needed...
    By MHolla in forum General Tech Discussion
    Last Post: 07-11-2009, 08:50 AM
  4. Power Windows
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 03-12-2008, 08:51 PM
  5. Power Windows
    By stlmo_gtp in forum Off Topic Discussion
    Last Post: 03-08-2008, 03:58 AM
