Thread: What next to test for power windows?
Results 1 to 20 of 30
  1. #1 Re: What next to test for power windows?
    SE Level Member Burley117's Avatar
    Nov 2011
    Kalamazoo, MI
    Did you every find a solution to your problem here? I'm having similar symptons and curious what you ended up doing.
    06 Grand Prix, 01 Grand Prix GT, 98 Grand Prix GT, 98 GrandPrix GTP
  2. #2 Re: What next to test for power windows?
    Jun 2014
    Maryland, USA
    Quote Originally Posted by Burley117 View Post
    What my issue was a relay hidden in the dash, it took some digging and probing around to find it. If you need more information about which relay it was, I'd be glad to do what I can to help!
  3. #3 Re: What next to test for power windows?
    Nov 2011
    Kalamazoo, MI
    Quote Originally Posted by JayHerlth View Post
    Any advice here?
  4. #4 Re: What next to test for power windows?
    Jun 2014
    Maryland, USA
    Any advice here?
    Crap, my bad for ignoring these forums for a while. It was hidden behind the glove box from what I remember. So you're most likely going to have to remove that so you can get 100% behind that area. It was a large 4 pin relay (I believe there were two near each other) tucked up in there. Two larger wires were red and blue? I'm colorblind too, so I'm probably imagining colors lol. Check that to see if it's powering on.
    Though I don't think that's it, considering you've got a good side working. My next best guess is to check the harness going through the door for any cracks for frays. I would say your switch in general could be bad, but I'm sure you figured out it's not the issue by testing the switch on that physical side. I want to say that without a working master switch, all of the windows or some will not work. I feel like I came across that in the midst of trying to figure out my window situation.
    Considering it's 1:20AM here, I'll see about getting a photo up if I can remember. I'll have to remove the glovebox since I put it on after fixing the job.
  1. Power windows don't go down
    By schwarry in forum Shops and Community Heroes
    Last Post: 01-03-2013, 01:02 AM
  2. Windows Have No Power
    By Solid Steel in forum Audio, Security & Visual Electronics
    Last Post: 04-16-2012, 02:03 PM
  3. windows go up/down with no power....
    By urnotaslave23 in forum General Tech Discussion
    Last Post: 05-29-2011, 06:49 PM
  4. Power Windows
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 03-12-2008, 08:51 PM
  5. Power Windows
    By stlmo_gtp in forum Off Topic Discussion
    Last Post: 03-08-2008, 03:58 AM
