I tested the output wires to the motor from the switch. Then being curious tested the positive wire to the physical switch from the boot side & I think it was around 0.23 volts.
Car was running, battery is fine, fuse was in and a new fuse at that. I know nothing about electronics in a car, though it doesn't sound normal to have that little going into a car window. If there was a break in the wire I would assume my meter would read zero.
