BillBoost37
Ok.. so you aren't getting power to the main switch.. which is an issue. You did get harnesses from the same year car, right? And the big power wire did line up in the connector and neither wire pushed back out? It's a pain..but it's the little things. Other than that..there's like a relay in or controlled by the bcm (body control) that gives the windows power. I'd check the in and out of that relay as well.
