Thread: Cylinder 3 misfire Tried everything I can think of
Results 1 to 20 of 74
Threaded View
Beelzeboul Cylinder 3 misfire Tried... 08-20-2012, 08:10 PM
Beelzeboul Re: Cylinder 3 misfire Tried... 09-04-2012, 03:28 PM
gloebird Re: Cylinder 3 misfire Tried... 09-04-2012, 03:32 PM
Beelzeboul Re: Cylinder 3 misfire Tried... 09-04-2012, 03:44 PM
97gtsc Re: Cylinder 3 misfire Tried... 09-04-2012, 03:44 PM
blueguy Re: Cylinder 3 misfire Tried... 09-04-2012, 04:03 PM
brandonl2000 Re: Cylinder 3 misfire Tried... 09-04-2012, 04:04 PM
blueguy Re: Cylinder 3 misfire Tried... 09-04-2012, 04:05 PM
Rico Re: Cylinder 3 misfire Tried... 09-04-2012, 05:16 PM
Beelzeboul Re: Cylinder 3 misfire Tried... 09-04-2012, 05:25 PM
dbextreme Re: Cylinder 3 misfire Tried... 09-04-2012, 07:44 PM
Beelzeboul Re: Cylinder 3 misfire Tried... 09-04-2012, 07:50 PM
dbextreme Re: Cylinder 3 misfire Tried... 09-04-2012, 07:57 PM
Beelzeboul Re: Cylinder 3 misfire Tried... 09-04-2012, 08:04 PM
Swiggles Did you gap your plugs right?... 09-04-2012, 08:12 PM
Beelzeboul Re: Cylinder 3 misfire Tried... 09-04-2012, 08:16 PM
Swiggles Thanks What are your mods?... 09-04-2012, 08:20 PM
86bcook Re: Cylinder 3 misfire Tried... 09-04-2012, 10:12 PM
97gtsc Re: Cylinder 3 misfire Tried... 09-05-2012, 12:09 AM
Beelzeboul Re: Cylinder 3 misfire Tried... 09-05-2012, 01:18 PM
Beelzeboul Re: Cylinder 3 misfire Tried... 09-05-2012, 04:15 PM
Beelzeboul Re: Cylinder 3 misfire Tried... 09-05-2012, 08:34 PM
Beelzeboul Re: Cylinder 3 misfire Tried... 09-06-2012, 12:36 PM
Beelzeboul Re: Cylinder 3 misfire Tried... 09-06-2012, 07:58 PM
Swiggles You'll know your getting fuel... 09-07-2012, 08:17 PM
Beelzeboul Re: Cylinder 3 misfire Tried... 09-08-2012, 08:04 PM
brandonl2000 Re: Cylinder 3 misfire Tried... 09-09-2012, 01:36 AM
sseilmnop Ive found small vacuum leaks... 09-09-2012, 02:49 AM
Tony Mendez Re: Cylinder 3 misfire Tried... 09-09-2012, 03:00 AM
Beelzeboul Re: Cylinder 3 misfire Tried... 09-09-2012, 09:24 AM
Fivefingerdeathpunch Re: Cylinder 3 misfire Tried... 09-10-2012, 12:45 AM
Beelzeboul Re: Cylinder 3 misfire Tried... 09-10-2012, 01:23 AM
thatguy Re: Cylinder 3 misfire Tried... 09-09-2012, 09:25 AM
Tony Mendez Re: Cylinder 3 misfire Tried... 09-09-2012, 09:50 AM
Beelzeboul Re: Cylinder 3 misfire Tried... 09-09-2012, 03:21 PM
Tony Mendez Re: Cylinder 3 misfire Tried... 09-09-2012, 10:56 PM
Beelzeboul Re: Cylinder 3 misfire Tried... 09-10-2012, 12:06 AM
Fivefingerdeathpunch Re: Cylinder 3 misfire Tried... 09-11-2012, 12:45 AM
Beelzeboul Re: Cylinder 3 misfire Tried... 09-11-2012, 12:23 PM
Beelzeboul Re: Cylinder 3 misfire Tried... 09-11-2012, 05:15 PM
Tony Mendez Re: Cylinder 3 misfire Tried... 09-11-2012, 07:59 PM
Beelzeboul Re: Cylinder 3 misfire Tried... 09-11-2012, 08:03 PM
Tony Mendez Re: Cylinder 3 misfire Tried... 09-11-2012, 08:38 PM
brandonl2000 Re: Cylinder 3 misfire Tried... 09-12-2012, 12:18 AM
Beelzeboul Re: Cylinder 3 misfire Tried... 09-13-2012, 11:00 AM
Swiggles Order a stock replacement... 09-13-2012, 11:09 AM
Beelzeboul Re: Cylinder 3 misfire Tried... 09-13-2012, 11:16 AM
Tony Mendez Re: Cylinder 3 misfire Tried... 09-13-2012, 07:52 PM
Beelzeboul Re: Cylinder 3 misfire Tried... 09-16-2012, 12:36 PM
Beelzeboul Re: Cylinder 3 misfire Tried... 09-24-2012, 09:17 PM
Beelzeboul Re: Cylinder 3 misfire Tried... 09-25-2012, 01:40 PM
SDGTP99 Re: Cylinder 3 misfire Tried... 09-25-2012, 02:05 PM
Beelzeboul Re: Cylinder 3 misfire Tried... 09-25-2012, 03:33 PM
SDGTP99 Re: Cylinder 3 misfire Tried... 09-25-2012, 03:55 PM
Beelzeboul Re: Cylinder 3 misfire Tried... 09-25-2012, 04:00 PM
Beelzeboul Re: Cylinder 3 misfire Tried... 09-25-2012, 04:21 PM
matt5112 Map should never be positive... 09-25-2012, 04:57 PM
Beelzeboul Re: Cylinder 3 misfire Tried... 09-25-2012, 05:12 PM
SDGTP99 Re: Cylinder 3 misfire Tried... 09-25-2012, 05:53 PM
SDGTP99 Re: Cylinder 3 misfire Tried... 09-25-2012, 05:52 PM
matt5112 Re: Cylinder 3 misfire Tried... 09-25-2012, 06:24 PM
Beelzeboul Re: Cylinder 3 misfire Tried... 09-25-2012, 06:34 PM
matt5112 Re: Cylinder 3 misfire Tried... 09-25-2012, 06:38 PM
Beelzeboul Re: Cylinder 3 misfire Tried... 09-25-2012, 06:52 PM
matt5112 Re: Cylinder 3 misfire Tried... 09-25-2012, 07:01 PM
Beelzeboul Re: Cylinder 3 misfire Tried... 09-25-2012, 07:08 PM
Beelzeboul Re: Cylinder 3 misfire Tried... 09-25-2012, 07:30 PM
Rico Re: Cylinder 3 misfire Tried... 09-27-2012, 12:52 PM
01GrandPrixTURBOGT Re: Cylinder 3 misfire Tried... 01-10-2013, 12:40 AM
Beelzeboul Re: Cylinder 3 misfire Tried... 01-11-2013, 12:29 PM
01GrandPrixTURBOGT Re: Cylinder 3 misfire Tried... 01-12-2013, 09:03 AM
Scott Gerhart I have this same problem.... 01-17-2013, 11:28 AM
Iceman6669 I have not seen you on here... 01-19-2013, 11:22 AM
kawasakidrivinghick Re: Cylinder 3 misfire Tried... 01-27-2013, 09:39 AM
  1. #1 Cylinder 3 misfire Tried everything I can think of
    GT Level Member Beelzeboul's Avatar
    Racine
    All I know about it is
    It's not an injector(swapped)
    It's not a chipped cylinder(compression test)
    it's not a plug(swapped and gauge checked 3 times)
    it's not a wire(swapped)
    it's not a coil(swapped)
    It's not a ICM(swapped)
    also seafoamed
    and cleaned MAF
    problem is confined to cylinder 3 regardless of components
    the problem is intermittent at best nowadays seemed to get alot better after switching to 93 octane
    could bad gas alone cause a misfire?
    problem occurred after doing headers and plugs
    could a bad exhaust leak cause a misfire?
    I'm sorry officer I didnt know I couldn't do that
  1. Cylinder #3 misfire
    By Newby101 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-15-2011, 03:02 PM
  2. Misfire in Cylinder 6
    By Porach in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-08-2011, 02:19 AM
  3. From misfire at cylinder 3 to a open circuit on the fuel injecter at cylinder 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 07:49 PM
  4. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
  5. Cylinder #4 misfire
    By Kompton in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2009, 08:41 AM
