Thread: 00 GTP issues with a rough start every now and then
Results 1 to 2 of 2
  1. #1 00 GTP issues with a rough start every now and then
    Jan 2013
    Gainesville, Fl
    I have a 2000 Grand Prix GTP. I have had an issue with the car starting. It happens after I have it run and turn it off then I let it sit for a short period and when I start it up again it just cranks but doesn't start up. I am thinking it maybe a fuel pressure regulator or a fuel pump relay. Anyone have any ideas? It is not throwing a check engine light. The Fuel pressure is at 48 psi with the key on motor off. According to Alldata that is ok... I have not been able to replicate the issue when I have the fuel pressure guage attached. When it happened the first time my friend check to see if there was any pressure and he said nothing was coming out. Once it starts up I don't seem to have any issues. Thanks!
  2. #2 Re: 00 GTP issues with a rough start every now and then
    St. Louis
    When it cranks over but doesn't start, do you hear the fuel pump hum for a few seconds when the key gets to "on"? Wondering if your pump is starting to fail.
  1. rough start
    By honda237 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-01-2011, 08:58 AM
  2. rough start
    By mosley in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-27-2011, 01:15 PM
  3. Rough start
    By 06grandprix93 in forum General Tech Discussion
    Last Post: 10-22-2010, 05:12 PM
  4. Rough start-up
    By DanGTP in forum PCM Tuning
    Last Post: 02-08-2010, 12:16 AM
  5. Rough Start
    By Willthesage in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-16-2009, 11:56 AM
