Thread: Cylinder 3 misfire Tried everything I can think of
Results 1 to 20 of 74
  1. #1 Re: Cylinder 3 misfire Tried everything I can think of
    GT Level Member Tony Mendez's Avatar
    Aug 2012
    Somerset WI
    Some things I do when dealing with problems similar to yours: I eliminate mechanical causes...lifters, valves, etc. Perform a relative compression test. When I am satisfied the engine is mechanically sound I move on to the fuel system...fuel pressure both at idle and when driving down the road, specifically when duplicating problem. Scope injectors. Perform a injector balance test. A faulty injector will quickly become apparent during this test. It is important to note that after performing an injector balance test that the vehicle be started and run to burn off the fuel that will accumulate in the cylinders during the test. I also like to run a injector kill test from time to time. Once I have eliminated fuel delivery and injector function as the cause I move on to secondary ignition. Visually check for arcing or faulty components. Simply put, current is alot like water...it will flow to the path of least resistance. If your secondary ignition can find a path to ground thats easier than the path it takes from coil to spark plug, it will follow that path. This is more pronounced under load. I like to monitor fuel trims when looking for secondary ignition issues. STFT should remain relatively low, +/- 5% up to 8%. LTFT should show a relatively steady reading of around 10% up to 14%. Try and keep the PID list down to 4 selected items to ensure a quicker data refresh rate. A weak or intermittent secondary ignition fault will show up as higher fuel trims. Once you have pinpointed your problem and correct it, I highly recommend clearing your KAM. The PCM has learned a strategy based on the conditions you have been driving your car under with the misfire. Dump that garbage and let your PCM relearn a strategy based on a properly performing engine.
  2. #2 Re: Cylinder 3 misfire Tried everything I can think of
    GT Level Member Beelzeboul's Avatar
    Racine
    thanx alot for the walk through at least I know what I've done up to this point is right on task my FTs are right where you saying they should be along with my boost staying at -10psi
    I had gone over alot of the connections last night ground from icm and harnesses trying to find anything lose or unstable everything seemed solid
    Im the exact same way when it comes to allowing the pcm to relearn tony not sure if its out of concern for my car or just an excuse to go open up the throttle afterwards
    one one question would be my fuel trims for instance if they were spiking high indicating a failure in the secondary ignition system how would I go about tracking it down
    I'm sorry officer I didnt know I couldn't do that
  3. #3 Re: Cylinder 3 misfire Tried everything I can think of
    Quote Originally Posted by Beelzeboul View Post
    VACUUM, should be at -19 to -20 at idle. And thats -19 in/hgs, because boost cant read negative numbers.
  4. #4 Re: Cylinder 3 misfire Tried everything I can think of
    Racine
    19-20 hgs is about 10psi aint it?
  1. Cylinder #3 misfire
    By Newby101 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-15-2011, 03:02 PM
  2. Misfire in Cylinder 6
    By Porach in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-08-2011, 02:19 AM
  3. From misfire at cylinder 3 to a open circuit on the fuel injecter at cylinder 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 07:49 PM
  4. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
  5. Cylinder #4 misfire
    By Kompton in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2009, 08:41 AM
