Thread: Cylinder 3 misfire Tried everything I can think of
Results 1 to 20 of 74
  1. #1 Re: Cylinder 3 misfire Tried everything I can think of
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    Safety isn't an issue, just don't run it for a long period of time because it will get MESSY!!! You're squirting oil all over and might catch fire on the headers. Slim but possible. I've adjusted rockers this way on several older V8's I've built. Just clean your header good afterwards and everything else.
    Did you switch coil packs around? I know you switched wires. Don't know about the ICM. My experience is they either work or don't, but could be a short in your ICM. Would a crack between your exhaust and intake valves show up on a compression check? Crack might show up more under more heat and that being a middle cyn. it gets hotter then the outer two.
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  2. #2 Re: Cylinder 3 misfire Tried everything I can think of
    GT Level Member Beelzeboul's Avatar
    Racine
    Quote Originally Posted by dbextreme View Post
    yeah thats what I was told about the cylinder 3 and 5 tend to be the leanest and misfire will occur in those first or chipped pistons or commonly 3
    dont think exhaust leaks would show up in compression test and yeah I had swapped coils and ICM both leaving me with the same intermittent misfire
    it actually got more dominant after swapping icm and than even out after a pcm relearn all my ftlts and vac levels seem appropriate though even at high speeds not sure if the vac would be affected by the exhaust leak either
    gonna check the valves tomorrow than just worried its not going to act up for me unless I throttle the hell out of it at the moment the problem only occurs on boost
    I'm sorry officer I didnt know I couldn't do that
  1. Cylinder #3 misfire
    By Newby101 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-15-2011, 03:02 PM
  2. Misfire in Cylinder 6
    By Porach in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-08-2011, 02:19 AM
  3. From misfire at cylinder 3 to a open circuit on the fuel injecter at cylinder 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 07:49 PM
  4. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
  5. Cylinder #4 misfire
    By Kompton in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2009, 08:41 AM
