yeah thats what I was told about the cylinder 3 and 5 tend to be the leanest and misfire will occur in those first or chipped pistons or commonly 3
dont think exhaust leaks would show up in compression test and yeah I had swapped coils and ICM both leaving me with the same intermittent misfire
it actually got more dominant after swapping icm and than even out after a pcm relearn all my ftlts and vac levels seem appropriate though even at high speeds not sure if the vac would be affected by the exhaust leak either
gonna check the valves tomorrow than just worried its not going to act up for me unless I throttle the hell out of it at the moment the problem only occurs on boost
