Thread: Cylinder 3 misfire Tried everything I can think of
Results 1 to 20 of 74
  1. #1 Re: Cylinder 3 misfire Tried everything I can think of
    GT Level Member Beelzeboul's Avatar
    Racine
    stock wires mods are headers intake and tstat. kinda presented itself this morning rather ugly first when i started car the pcm had reset suggesting my battery died over night
    looked around under hood and it looks like the sd hood cowls drip water right on top of my coil pack is this something I should be concerned about.
    I'll probably pick up a new set of wires today and hope it helps also found out I needed a new SC belt tension er so gonna be heading to the jy today to grab one after my doctors visit(thanx for the info about cylinder misfiring with swapped wires I can put something easy back of the list of possible culprits)
    the fact that the pcm went dead is kinda what threw me this morning leading me to believe it might be an electrical problem I took my battery halo and amp grounds off cleaned them all up and reinstalled
    gonna have to check valves as well afterwards is it just the couple bolts on valve cover I need to remove and not a gasket or anything ill have to replace and should pick up before attempting?
    will have a video up by tonight of my valves in motion
    but I was getting several backfires throughout the course of chasing my dogs down this morning along with stuttering I'm leaning towards wires or something as far as my fire components at fault
    I'm sorry officer I didnt know I couldn't do that
  1. Cylinder #3 misfire
    By Newby101 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-15-2011, 03:02 PM
  2. Misfire in Cylinder 6
    By Porach in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-08-2011, 02:19 AM
  3. From misfire at cylinder 3 to a open circuit on the fuel injecter at cylinder 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 07:49 PM
  4. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
  5. Cylinder #4 misfire
    By Kompton in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2009, 08:41 AM
