Thread: Cylinder 3 misfire Tried everything I can think of
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 74
  1. #1 Cylinder 3 misfire Tried everything I can think of
    GT Level Member Beelzeboul's Avatar
    Racine
    All I know about it is
    It's not an injector(swapped)
    It's not a chipped cylinder(compression test)
    it's not a plug(swapped and gauge checked 3 times)
    it's not a wire(swapped)
    it's not a coil(swapped)
    It's not a ICM(swapped)
    also seafoamed
    and cleaned MAF
    problem is confined to cylinder 3 regardless of components
    the problem is intermittent at best nowadays seemed to get alot better after switching to 93 octane
    could bad gas alone cause a misfire?
    problem occurred after doing headers and plugs
    could a bad exhaust leak cause a misfire?
    I'm sorry officer I didnt know I couldn't do that
  2. #2 Re: Cylinder 3 misfire Tried everything I can think of
    Racine
    edited post as problem became intermittent and than non existent and than intermittent and than gone again
  3. #3 Re: Cylinder 3 misfire Tried everything I can think of
    Dec 2011
    Orlando, FL
    this is going to sound ridiculous but make sure the wires are on the proper coils/plugs. after i did my headers and plugs i had the same thing. i couldn't believe i miss something that stupid. it's worth checking out.
  4. #4 Re: Cylinder 3 misfire Tried everything I can think of
    Racine
    yeah well I have adjusted them several times now swapping from 5-3 and than swapping wire 3 completely
    it was pretty obvious when I had them wired wrong on one occasion as soon as it fired up I could tell it was a consistent misfire
    this really only happens towards the higher RPMs and idle is completely normal around 700ish
  5. #5 Re: Cylinder 3 misfire Tried everything I can think of
    GTX Level Member 97gtsc's Avatar
    Jul 2008
    Livonia MI.
    How about checkn some of the grounds? theres 1 below the icm n the battery 1s.... clean them?
  6. #6 Re: Cylinder 3 misfire Tried everything I can think of
    Y u no do compression test?
  7. #7 Re: Cylinder 3 misfire Tried everything I can think of
    Grand Rapids, MI
    Quote Originally Posted by blueguy91 View Post
    Quote Originally Posted by Beelzeboul View Post
    didn't he?
  8. #8 Re: Cylinder 3 misfire Tried everything I can think of
    Actually.
    Don't mind my post.
    Carry on.
  9. #9 Re: Cylinder 3 misfire Tried everything I can think of
    Apr 2009
    Fort Worth TX
    Any ticking noises?
    A sticky valve guide may cause a miss only when the car is running.
    It could also be a lifter not pumping up.
  10. #10 Re: Cylinder 3 misfire Tried everything I can think of
    Racine
    never heard of a bad ground causing a misfire even than it seems a little odd that it would be the same cylinder every time and not shorting anything else out but ill go out and check over them Im usually good about all my electronics though.
    The lifters I will have to check can I just remove the valve cover and fire it to watch for which one is skipping?
    saw a video on a guy doing this wasn't sure on how safe that would be
  11. #11 Re: Cylinder 3 misfire Tried everything I can think of
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    Safety isn't an issue, just don't run it for a long period of time because it will get MESSY!!! You're squirting oil all over and might catch fire on the headers. Slim but possible. I've adjusted rockers this way on several older V8's I've built. Just clean your header good afterwards and everything else.
    Did you switch coil packs around? I know you switched wires. Don't know about the ICM. My experience is they either work or don't, but could be a short in your ICM. Would a crack between your exhaust and intake valves show up on a compression check? Crack might show up more under more heat and that being a middle cyn. it gets hotter then the outer two.
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  12. #12 Re: Cylinder 3 misfire Tried everything I can think of
    Racine
    Quote Originally Posted by dbextreme View Post
    yeah thats what I was told about the cylinder 3 and 5 tend to be the leanest and misfire will occur in those first or chipped pistons or commonly 3
    dont think exhaust leaks would show up in compression test and yeah I had swapped coils and ICM both leaving me with the same intermittent misfire
    it actually got more dominant after swapping icm and than even out after a pcm relearn all my ftlts and vac levels seem appropriate though even at high speeds not sure if the vac would be affected by the exhaust leak either
    gonna check the valves tomorrow than just worried its not going to act up for me unless I throttle the hell out of it at the moment the problem only occurs on boost
  13. #13 Re: Cylinder 3 misfire Tried everything I can think of
    Nov 2009
    Tennessee
    *smacks forehead* I read that, I just got to thinking and forgot you did all that already.. LOL Sorry!!
  14. #14 Re: Cylinder 3 misfire Tried everything I can think of
    Racine
    np I've been smacking my forehead for about a month now what bothers me is how touchy it is things will run better than fine for a day than bog for an hour than run fine again really weird I have a video of the symptom in my photo bucket via my profile showing it at its absolute worst
    Quincy, Mass
    Did you gap your plugs right?
    Also have you taken the valve covers off to check for a broken spring or bent pushrod?
    No more GP 04 Impala SS Indy:
  16. #16 Re: Cylinder 3 misfire Tried everything I can think of
    Racine
    yeah 3 times the problem seemed more dominant at the 58 mark I read to gap them at initially so I took them all out and re gapped down to 50 but while worrying about the chipped cylinder I checked it again for damage and made sure it was still at 50 and another time when compression test was done ad even swapped plugs one more time to be sure
    should they be gapped below 50? tr105s i believe (went with the one range cooler ngk)
    ps your rims are hawt swiggle
    Quincy, Mass
    Thanks
    What are your mods? If your stock try the stock sized plugs.
  18. #18 Re: Cylinder 3 misfire Tried everything I can think of
    SE Level Member 86bcook's Avatar
    Aug 2012
    Borger, Tx
    mine was misfiring on cylinder 3 also, the other day. i swapped coils, and plug wires, puts new plugs in it, seafoamed it. i was clueless. than i desided to get my multimeter and check ohms on the wires. it ended up being a crappy plug wires.so i replaced the wires and it runs great now. when i swapped coils and wires it really didnt change to another cylinder
  19. #19 Re: Cylinder 3 misfire Tried everything I can think of
    Jul 2008
    Livonia MI.
    What kinda plug wires u runnin?
  20. #20 Re: Cylinder 3 misfire Tried everything I can think of
    Racine
    stock wires mods are headers intake and tstat. kinda presented itself this morning rather ugly first when i started car the pcm had reset suggesting my battery died over night
    looked around under hood and it looks like the sd hood cowls drip water right on top of my coil pack is this something I should be concerned about.
    I'll probably pick up a new set of wires today and hope it helps also found out I needed a new SC belt tension er so gonna be heading to the jy today to grab one after my doctors visit(thanx for the info about cylinder misfiring with swapped wires I can put something easy back of the list of possible culprits)
    the fact that the pcm went dead is kinda what threw me this morning leading me to believe it might be an electrical problem I took my battery halo and amp grounds off cleaned them all up and reinstalled
    gonna have to check valves as well afterwards is it just the couple bolts on valve cover I need to remove and not a gasket or anything ill have to replace and should pick up before attempting?
    will have a video up by tonight of my valves in motion
    but I was getting several backfires throughout the course of chasing my dogs down this morning along with stuttering I'm leaning towards wires or something as far as my fire components at fault
  1. Cylinder #3 misfire
    By Newby101 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-15-2011, 03:02 PM
  2. Misfire in Cylinder 6
    By Porach in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-08-2011, 02:19 AM
  3. From misfire at cylinder 3 to a open circuit on the fuel injecter at cylinder 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 07:49 PM
  4. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
  5. Cylinder #4 misfire
    By Kompton in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2009, 08:41 AM
