Thread: Some more top swap questions! Yay!
Page 46 of 71 FirstFirst ... 36444546474856 ... LastLast
Results 901 to 920 of 1411
  1. #901 Re: Some more top swap questions! Yay!
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    I would baby the **** outta it untill you get the tune fixed . How does it run? Is it pretty quick?
    Sent from my SM-G920V using Tapatalk
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  2. #902 Re: Some more top swap questions! Yay!
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Well a tune should fix it right even if they have to pull a bunch of timing right?
    Sent from my LG-D851 using Tapatalk
  3. #903 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    Yeah it should how much timing do you have now?
  4. #904 Re: Some more top swap questions! Yay!
    Oct 2015
    I have absolutely no clue. Ill send reptile a pm unless theres a way to tell with toerque pro
  5. #905 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    Never used the torque pro
  6. #906 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    But from what I know and zzp explained to me kr is bad real bad in a boosted motor not so much in N/A. They told me anything over 2° kr let off the gas you can ruin your motor that quick
  7. #907 Re: Some more top swap questions! Yay!
    you vets brother or cousin now? t app works just fine for his needs. i use it all the time, shows the same data as dhp scans.
  8. #908 Re: Some more top swap questions! Yay!
    Oct 2015
    Scotty what does the timing advance in torque pro do?
  9. #909 Re: Some more top swap questions! Yay!
    thats your timing. will be around 20 at idle, drop to like 15 wot.
  10. #910 Re: Some more top swap questions! Yay!
    Oct 2015
    O ok i didnt know if that was the same thing as what we were talking about. It is right at 20 at idle i didnt go wot just gave it a little rev and it went up to about 24 at 2500 rpm
  11. #911 Re: Some more top swap questions! Yay!
    revving it in park is not the same as wot.
  12. #912 Re: Some more top swap questions! Yay!
    Oct 2015
    I know that... Lol ok well ill just call some local tuners in the a.m maybe i can get a tune done tomorow if they dont rape me. How much is a good tune? My dad got his firehawk tuned at a shop nearby but they charged him over 500$ granted he did a ton of passes on the dyno
  13. #913 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    Normally 3 passes for 100 bucks
  14. #914 Re: Some more top swap questions! Yay!
    you can get a dhp for 250, im sure you have a laptop already. most everyone does.
  15. #915 Re: Some more top swap questions! Yay!
    Oct 2015
    Well actually i dont have a laptop at the moment granted im sure i could get a cheap older one for 80 bucks or something but i still have no idea how to tune or even a wideband
  16. #916 Re: Some more top swap questions! Yay!
    Oct 2015
    I read on a post here that i can take off the sc belt and take it for a test drive and if im experiencing no kr or very little then that would determine its 100% real kr. Is that true?
  17. #917 Re: Some more top swap questions! Yay!
    Donating Users timboku's Avatar
    Montgomery, IL
    What are your ltfts (long term fuel trim) at idle and cruising? Also pull up your 02 sensor 1 bank 1 to make sure it's reading correctly..it should bounce around. Start there to fake sure you don't have a mechanical problem like a band 02 sensor or a vacuum leak on headers or intake..
    Pic or refrence on what my torque looks like on my tablet,.don't look at the values as I had and issue...but you want your ltft and stft should be + or - 5% at least. Also your pcm is still learning..you shouldn't do WOT runs until a good 20 to 30 mins of light throttle smooth acceleration and long steady cruising speeds in 3rd gear....check your trims while doing this..they should improve, if not there is a mechanical issue.
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  18. #918 Re: Some more top swap questions! Yay!
    Kemmerer, Wyoming
    Quote Originally Posted by Tonkin2000GT View Post
    I'm not trying to be a jerk, but it will probably come out that way, but I really don't want to hear you say: "zzp told me" they might know a few things, but you need to find reliable sources to learn from.
  19. #919 Re: Some more top swap questions! Yay!
    Kemmerer, Wyoming
    Quote Originally Posted by suitercrew View Post
    you can take the supercharger belt off and drive it. no big deal, it happens often. if your kr is only showing up with wot pulls, I would just drive it, and stay out of the boost.
  20. #920 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    Quote Originally Posted by SgtMarshal View Post
    LOL dude honestly I don't give a **** what you want to hear zzp may have there issues but they do know what there talking about hence the reason they have a 8 second drag car smfh
  1. top swap questions
    By 1976beef in forum Introductions/Noob Questions
    Last Post: 10-31-2015, 05:58 PM
  2. e85 swap questions
    By 04lss in forum Introductions/Noob Questions
    Last Post: 09-30-2014, 03:13 PM
  3. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  4. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
