Thread: Some more top swap questions! Yay!
Page 36 of 71 FirstFirst ... 26343536373846 ... LastLast
Results 701 to 720 of 1411
  1. #701 Re: Some more top swap questions! Yay!
    hey before you go bolting the heads back on.
    put your o2 sensor in the rear header, then lay your header in the back, then put the head on the engine, then pull the header to the head studs and nut it on there. then mark the fire wall where the o2 is close to hitting. unbolt the header remove the head and header, then dent the fire wall in. you will never have this much room to work in to clearance the o2.
  2. #702 Re: Some more top swap questions! Yay!
    Quote Originally Posted by suitercrew View Post
    Well im gonna reuse my l36 pushrods and rockers since i wasnt able to get the 1.9s so there still pretty oily haha
    Sent from my LG-D851 using Tapatalk
    scrub them up clean, dont put dirty parts back on.
  3. #703 Re: Some more top swap questions! Yay!
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Well i was going to put the front head on and set up the front header portion and then work on the back cause i have both dogbones out right now to get more clearance in the front. Theres 0 clearance in the back right now
  4. #704 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok ill get scrubbn!
  5. #705 Re: Some more top swap questions! Yay!
    front header is the last part that goes on. you read the header install thread yet?
    is the rear head on still? once you get the two brackets off the head you can see wtf your doing real easy.
  6. #706 Re: Some more top swap questions! Yay!
    Oct 2015
    The rear head is still on
  7. #707 Re: Some more top swap questions! Yay!
    get the alt and the brackets off and you can see every thing. leave the two brackets off too, and the one on the front head. cleans up the engine, you dont need em.
  8. #708 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok scotty! So no adjustment is needed on the rocker arms right?
  9. #709 Re: Some more top swap questions! Yay!
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    Adjustment on the rocker arms???? What are you talking about they don't adjust lol that's what hydraulic lifters are for...
    Sent from my SM-G920V using Tapatalk
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  10. #710 Re: Some more top swap questions! Yay!
    Oct 2015
    Lol thats what i thought my dad just kept asking me if i knew how to adjust them. (hes a little old school)
  11. #711 Re: Some more top swap questions! Yay!
    its not a solid lifter cam. line em up tq em down.
    if you spin the engine so both valves are closed then tq em, you know they are all done evenly. use the crank bolt to spin the engine.
  12. #712 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok
  13. #713 Re: Some more top swap questions! Yay!
    Oct 2015
    So after 30 minutes i finally got the whole 4 bolts off that hold the black brackets on and you were right scotty without those stupid brackets its a lot easier.
  14. #714 Re: Some more top swap questions! Yay!
    Oct 2015
    Can someone tell me if these are tty or reusable? I ordered the reusable but on their website it says the torque specs are 25ft lbs but on the bag it give different torque specs with the extra degreees which makes me believe they messed up and sent me tty
  15. #715 Re: Some more top swap questions! Yay!
    what bolts are they? brand? if they are tty i think the bolt head is marked.
    the allen head rocker bolts are re usable for sure.
  16. #716 Re: Some more top swap questions! Yay!
    Oct 2015
  17. #717 Re: Some more top swap questions! Yay!
    sounds like a tty spec to me. odd for sure.
  18. #718 Re: Some more top swap questions! Yay!
    Oct 2015
    So hmm.. Call intense i guess? Lol i finally got the rear head off and manifold and dp. Almost ready to start putting it back together!!
  19. #719 Re: Some more top swap questions! Yay!
    SE Level Member duswickware's Avatar
    Jan 2014
    mansfield, ohio
    I bought these same bolts from intense, checked out as reusable but came packaged the same way.
  20. #720 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok thanks! So do they get torqued to 25ft lbs?
  1. top swap questions
    By 1976beef in forum Introductions/Noob Questions
    Last Post: 10-31-2015, 05:58 PM
  2. e85 swap questions
    By 04lss in forum Introductions/Noob Questions
    Last Post: 09-30-2014, 03:13 PM
  3. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  4. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
