Thread: Some more top swap questions! Yay!
Page 56 of 71 FirstFirst ... 646545556575866 ... LastLast
Results 1,101 to 1,120 of 1411
  1. #1101 Re: Some more top swap questions! Yay!
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    The thing is you didn't have a misfire originally when you first started the motor after the top swap correct?
    Sent from my SM-G920V using Tapatalk
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  2. #1102 Re: Some more top swap questions! Yay!
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Well for starters its not like i can feel the misfire and it has never popped up as a real code only as a pending code. It also doesnt pop up right away i cleared the codes 3 times today and each time it took atleast 15 mins to come back.
    Sent from my LG-D851 using Tapatalk
  3. #1103 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    It's either you have a misfire or you don't it wouldn't show up if you didn't have it
  4. #1104 Re: Some more top swap questions! Yay!
    Oct 2015
    Well ya im just saying its not like the light came on so i have no idea when it first popped up. Im thinking injector what else could it be?
  5. #1105 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    Valve or a hole in the piston I don't think you understand how bad 4° of kr is and what it can do
  6. #1106 Re: Some more top swap questions! Yay!
    Oct 2015
    What would be wrong with the valve?
  7. #1107 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    I'd do a compression check first that'll narrow it down then if that's good I'd get a bore scope and look down the cylinder
  8. #1108 Re: Some more top swap questions! Yay!
    Oct 2015
    Well first im switching the fuel injectors. Keep in mind these are jy injectors thats the cheapest fastest posibilittly here. I lapped all the valves the cylinder was in great condition and ive been getting a shake from the motor ever since first start up. I got money on the injector
  9. #1109 Re: Some more top swap questions! Yay!
    Oct 2015
    So switched injectors around and still getting cylinder 3 missfire.. Also just got a pending code for p0654 which is engine speed output. Any ideas guys?
  10. #1110 Re: Some more top swap questions! Yay!
    http://www.autocodes.com/p0654_pontiac.html
    you might have a beat pcm, being you just changed it.
  11. #1111 Re: Some more top swap questions! Yay!
    Oct 2015
    Would that have anything to do with the missfire?
  12. #1112 Re: Some more top swap questions! Yay!
    hard to say really.contact reptile, see what he says about the newest code.
  13. #1113 Re: Some more top swap questions! Yay!
    Oct 2015
    Maybe this could explain why my cel supposedly just went out at the same exact time i did the swap
  14. #1114 Re: Some more top swap questions! Yay!
    either that or your cluster is messed up, as per the code list of thinks to check.
    the car will run with the cluster removed. theres 4 small bolts that hold it in after you pop the trim off. unplug it, take it out, see if its still acting up.
  15. #1115 Re: Some more top swap questions! Yay!
    Oct 2015
    Well i have to work all day so i wont have much time for that :/ but what do you think about the missfire im pretty sure i have checked everything but the voltage on the injector connector. Everything else is gonna be head or piston failure i believe. *Sighh*
  16. #1116 Re: Some more top swap questions! Yay!
    Oct 2015
    Could it be something easy like a stuck lifter or something on that cylinder or if it was a gasket leak where could it leak from that wouldnt get coolant in my oil or vice versa or affect another cylinder?
  17. #1117 Re: Some more top swap questions! Yay!
    Kemmerer, Wyoming
    You are over complicating the issue like I always do
  18. #1118 Re: Some more top swap questions! Yay!
    Quote Originally Posted by suitercrew View Post
    nothing easy about a stuck lifter, aka thats a dead engine. and you'd hear that. gaskets are fine or you'd know it.
    4º of kr is a top swap killer aka hello chipper.
    being you got that new code, i suspect the pcm, maybe the cause of it all. after all they are used pcm's with no real history of how they worked in the past.
  19. #1119 Re: Some more top swap questions! Yay!
    Oct 2015
    Hmm maybe i can get reptile to send another. Also noticed something odd driving to work when i let off the gas and coasting to a red light my vaccum goes down to around -22 but then for no reason it will start bouncing inbetween -22 and -15 still coasting with foot off the gas
  20. #1120 Re: Some more top swap questions! Yay!
    take the sc belt off put your stock pcm back in, see if it has the same codes pop up. and if the fuel trims head to a normal place.
  1. top swap questions
    By 1976beef in forum Introductions/Noob Questions
    Last Post: 10-31-2015, 05:58 PM
  2. e85 swap questions
    By 04lss in forum Introductions/Noob Questions
    Last Post: 09-30-2014, 03:13 PM
  3. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  4. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
