Thread: Some more top swap questions! Yay!
Results 1 to 20 of 1411
Threaded View
  1. #11 Re: Some more top swap questions! Yay!
    Donating Users timboku's Avatar
    Montgomery, IL
    What are your ltfts (long term fuel trim) at idle and cruising? Also pull up your 02 sensor 1 bank 1 to make sure it's reading correctly..it should bounce around. Start there to fake sure you don't have a mechanical problem like a band 02 sensor or a vacuum leak on headers or intake..
    Pic or refrence on what my torque looks like on my tablet,.don't look at the values as I had and issue...but you want your ltft and stft should be + or - 5% at least. Also your pcm is still learning..you shouldn't do WOT runs until a good 20 to 30 mins of light throttle smooth acceleration and long steady cruising speeds in 3rd gear....check your trims while doing this..they should improve, if not there is a mechanical issue.
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  1. top swap questions
    By 1976beef in forum Introductions/Noob Questions
    Last Post: 10-31-2015, 05:58 PM
  2. e85 swap questions
    By 04lss in forum Introductions/Noob Questions
    Last Post: 09-30-2014, 03:13 PM
  3. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  4. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
