Thread: Some more top swap questions! Yay!
Page 45 of 71 FirstFirst ... 35434445464755 ... LastLast
Results 881 to 900 of 1411
  1. #881 Re: Some more top swap questions! Yay!
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    Yea you shouldn't have any kr something in your tune probably isn't right what do your fuel trims look like?
    Sent from my SM-G920V using Tapatalk
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  2. #882 Re: Some more top swap questions! Yay!
    did you do rockers too? if not those will help kill kr.
  3. #883 Re: Some more top swap questions! Yay!
    GXP Level Member suitercrew's Avatar
    Oct 2015
    No i didnt do rockers yet
    Sent from my LG-D851 using Tapatalk
  4. #884 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    I don't feel like you should have any kr with a stock pulley and headers/intake
  5. #885 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    Did you get rid of the regular fuel and put 93 in it?
  6. #886 Re: Some more top swap questions! Yay!
    Oct 2015
    Well idk the tune might be off it is canned and like scotty said the pcm hasnt even gone through a cycle so right now it still has to learn everything. Keep in mind also that a lot of stock gtp had kr right off the assembly line
  7. #887 Re: Some more top swap questions! Yay!
    if your still on a tank of 87, thats most of your kr i bet. the gas really matters.
  8. #888 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    Yea idk man 4° of kr is to much though. What about your fuel did you drain your tank and put 93 in?
  9. #889 Re: Some more top swap questions! Yay!
    Oct 2015
    It is running 100% 91 which is the highest grade in arizona
  10. #890 Re: Some more top swap questions! Yay!
    got e85 there?
  11. #891 Re: Some more top swap questions! Yay!
    Oct 2015
    Its not common but it it available
  12. #892 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    Idk your crazy to drive it with that much kr your asking for problems
  13. #893 Re: Some more top swap questions! Yay!
    give it a day or so, check your ltft's at wot, im sure it locks in at 0.0 still, they do that till they learn, then it will lock in one way or the other.
  14. #894 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok scotty ill give everyone a status update then. Also im getting a check engine light for some ml indicator malfuntion
  15. #895 Re: Some more top swap questions! Yay!
    Oct 2015
    P0650 is the code
  16. #896 Re: Some more top swap questions! Yay!
    means the cel light in the dash is not lighting up.
    tun key to run car off, you see the check engine light lit up? if not the bulb is out.
  17. #897 Re: Some more top swap questions! Yay!
    Oct 2015
    Service engine soon light is on but no cel. What are the chances that my cel bulb just happened to go out during this swap?
  18. #898 Re: Some more top swap questions! Yay!
    Oct 2015
    So what do you think scotty as far as i can tell im not getting any kr in regular driving 75% throttle is about 2 degrees and wot is about 4 is it good to drive for a week till i get it tuned?
  19. #899 Re: Some more top swap questions! Yay!
    you mean "service vehicle soon" works, check engine is out.
    the bulb in the cluster went out. iirc they are twist in bulbs.
  20. #900 Re: Some more top swap questions! Yay!
    Oct 2015
    Hmm that just seems odd it would go out right now lol. Seems like a good time to put those new needles in
  1. top swap questions
    By 1976beef in forum Introductions/Noob Questions
    Last Post: 10-31-2015, 05:58 PM
  2. e85 swap questions
    By 04lss in forum Introductions/Noob Questions
    Last Post: 09-30-2014, 03:13 PM
  3. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  4. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
