Thread: top swap questions
Results 1 to 4 of 4
  1. #1 top swap questions
    Oct 2015
    Illinois
    Hi all, im new here. My name is Corey, I bought a 2000 gp gt. And as my first pontiac car, i love it. So onto my question, My gp has a bad trans. as it doesnt have overdrive. So I bought a 2001 buick regal gs for cheap that has a nasty rod knock. It has the 4t65hd trans that i will be using in the gp. My question is, if i top swap the gp with parts from the buick, will i be able to use the ecm from the buick and not require any tuning?
  2. #2 Re: top swap questions
    It'll still need to be tuned, because the L36 is a higher compression ratio motor than the L67. You'd have alot better chance at internal engine damage without a tune or buy a 4.0 pulley to reduce the amount of boost made, even then it might not be "safe".
  3. #3 Re: top swap questions
    Oct 2015
    Illinois
    Ok thanks. What would need to be changed in the tune? Just retard the timing some more?
  4. #4 Re: top swap questions
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    Im pretty sure there is more to it than that. I have a top swap bin file i could send you if you have a way to load it into the PCM.
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  1. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  2. A Few Swap Questions
    By jaybaum96 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-12-2012, 07:18 PM
  3. Gen V Swap Questions
    By jdbaringer in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-23-2010, 12:44 PM
  4. Swap questions...
    By motohead in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-29-2009, 11:12 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
