Thread: Some more top swap questions! Yay!
Page 8 of 71 FirstFirst ... 6789101858 ... LastLast
Results 141 to 160 of 1411
  1. #141 Re: Some more top swap questions! Yay!
    Donating Users timboku's Avatar
    Montgomery, IL
    Quote Originally Posted by suitercrew View Post
    Well its complete except the pulleys are already off it and the supercharger, tb, and all that stuff up top is off but i already have a sc. Basically it has everything lim and down including coil pack bracket with coil packs
    Sent from my LG-D851 using Tapatalk
    Is he giving you all the pulleys and stuff for the 100? Or just block and heads?
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  2. #142 Re: Some more top swap questions! Yay!
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Well he has the supercharger belt tensioner but all the parts that actually spin and have the bearings are off it
  3. #143 Re: Some more top swap questions! Yay!
    Oct 2015
    How much do you guys think a case learn will cost?
  4. #144 Re: Some more top swap questions! Yay!
    Kemmerer, Wyoming
    Get yourself an Aeroforce scan gauge and you can do it yourself
  5. #145 Re: Some more top swap questions! Yay!
    Oct 2015
    I wouldnt even know where to start with that lol
  6. #146 Re: Some more top swap questions! Yay!
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Likeliness of a case relearn, is slim. So don't really think you need one. If you want to see if yours needs one, pull your current PCM and put it back in. If it runs like crap, then you know you need one later on. If not, don't worry about it.
  7. #147 Re: Some more top swap questions! Yay!
    Oct 2015
    Are you just talking about disconnecting the pcm cause ive done that before and didnt notice a difference. But i was planning on getting a reptile tune and his add says that i will need a case learn.
  8. #148 Re: Some more top swap questions! Yay!
    Apr 2015
    Yes, then you more than likely will not need one. I've already discussed this same issue with Bill saying I want a Reptile tune too, still said it's unlikely. Just put it in and if runs like poop, you need one. But if you've already unhooked your PCM, you shouldn't need one. Don't stress over it.
  9. #149 Re: Some more top swap questions! Yay!
    Oct 2015
    Well if it runs like crap ill probably just assume i ****'d up the top swap haha. I thought it set a code or something so you know that it needs a relearn?
  10. #150 Re: Some more top swap questions! Yay!
    you should do a crank learn for the hell of it, but if you really need one it will set a code for it.
  11. #151 Re: Some more top swap questions! Yay!
    Oct 2015
    So is there a way i can do it or is it dealer or hp tuner o ly kind of thing
  12. #152 Re: Some more top swap questions! Yay!
    Montgomery, IL
    I've put 3 different motors on my car and 3 different pcms and never had to case learn.
  13. #153 Re: Some more top swap questions! Yay!
    Oct 2015
    Well thats nice timboku check you pm
  14. #154 Re: Some more top swap questions! Yay!
    Quote Originally Posted by timboku View Post
    my engine was seemly running fine. no crank code, did a crank learn, (i got DHP) and it did run smoother.
  15. #155 Re: Some more top swap questions! Yay!
    Oct 2015
    Well i guess ill call the dealer and see how much it is and if its reasonable ill consider doing it
  16. #156 Re: Some more top swap questions! Yay!
    stop in at some local garages, see if they have a tech 2 scanner. if they do they can do it.
  17. #157 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok sounds like a plan thanks scotty
  18. #158 Re: Some more top swap questions! Yay!
    Oct 2015
    So timboku has been talking to me about emissions stuff but i want to get some more opinions on this. Last time i went i think they just plugged it in and looked under the hood but if they see headers isnt there a pretty good chance theyll check for a cat and if i have the rear o2 deleted wouldnt they see that on the scanner?
  19. #159 Re: Some more top swap questions! Yay!
    where you live? if you need a cat you install a high flow one for like 50 off ebay. what i did. passed NJ inspection.
    rear o2 can be deleted. cat, evap, egr. they cant tell, it just shows ready when they scan it like it should.
  20. #160 Re: Some more top swap questions! Yay!
    Oct 2015
    I live in Arizona and ok so its legal to only hace one o2? Also is it possible to just swap my old dp in place of the sd one just for emission testing?
  1. top swap questions
    By 1976beef in forum Introductions/Noob Questions
    Last Post: 10-31-2015, 05:58 PM
  2. e85 swap questions
    By 04lss in forum Introductions/Noob Questions
    Last Post: 09-30-2014, 03:13 PM
  3. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  4. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
