Thread: Some more top swap questions! Yay!
Page 7 of 71 FirstFirst ... 567891757 ... LastLast
Results 121 to 140 of 1411
  1. #121 Re: Some more top swap questions! Yay!
    yes that works. paint the lim too.
    i dint have the sc to sit on top the lim, so i taped it off. but you can set them up and paint both. tape off the sides of the lim where you dont want paint.
  2. #122 Re: Some more top swap questions! Yay!
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    What paint did you use? And do you have to prime everything beforehand? I want to do my S/C and throttle body silver, and then the fuel rail black.
  3. #123 Re: Some more top swap questions! Yay!
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Sweeeet
    Sent from my LG-D851 using Tapatalk
  4. #124 Re: Some more top swap questions! Yay!
    i used duplicolor high heat engine paint, and primer.
    and the same primer with hi heat black on all the little parts.
  5. #125 Re: Some more top swap questions! Yay!
    Apr 2015
    What did you use to clean the surfaces? I was thinking wire wheeling everything.
  6. #126 Re: Some more top swap questions! Yay!
    see the wire wheel set there lol and brake cleaner. if stuff is real rusty wear a dust mask.
    my block was a rust coated beast. first cleaned piston top lol
  7. #127 Re: Some more top swap questions! Yay!
    Apr 2015
    I'll just wire wheel the top of the S/C and throttle body. Fuel rail don't need to be cleaned up. Just painted right away.
  8. #128 Re: Some more top swap questions! Yay!
    clean the heads and paint them too. you cant see much past there really.
  9. #129 Re: Some more top swap questions! Yay!
    Apr 2015
    I'll paint them black then lol.
  10. #130 Re: Some more top swap questions! Yay!
    what ever color you like. its yours. you think i asked if i should paint mine yellow? no i did not lol
  11. #131 Re: Some more top swap questions! Yay!
    Apr 2015
    Quote Originally Posted by ScottyDoggs View Post
    My color scheme is black and silver. So a silver S/C/LIM/TB and a black fuel rail and heads for contrast.
  12. #132 Re: Some more top swap questions! Yay!
    Oct 2015
    Im assuming theres no prep when painting the sc and stuff besides cleaning. Like no scuffing are sanding balognie right?
  13. #133 Re: Some more top swap questions! Yay!
    clean and paint. thats it. all i did.
  14. #134 Re: Some more top swap questions! Yay!
    Oct 2015
    So i drove to pick up my heads today and the guy didnt have them off the block yet and i didnt have enough time to wait any longer but he had two gtps and it was nice to meet a fellow enthusiast in Arizona! He also told me he would sell me the whole motor for 100$ but i dont know if it worth it since he spun a bearing
  15. #135 Re: Some more top swap questions! Yay!
    Oct 2015
    Hey guys so im sure there is a thread or a how to for top swapping but i cant find it, i can only find the one with the parts list. What do i do with the balancer shaft when i topswap?
  16. #136 Re: Some more top swap questions! Yay!
    Nothing. Leave it a Lone.
  17. #137 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok ya i saw a thread of a guy talking about the balancer having to come off and how it wouldnt be that hard to do a cam and timing chain at that time. I thought he was talking about the balancer shaft but now i re read it and assume bhe was just talking about the hb
  18. #138 Re: Some more top swap questions! Yay!
    Kemmerer, Wyoming
    Quote Originally Posted by suitercrew View Post
    if you do a top swap, the harmonic balancer has to come off and get replaced with a supercharger version, otherwise there is no way for the supercharger to have a belt that will turn it. once you have the harmonic balancer off, it isn't a lot more work to take the timing cover off and change the cam.
  19. #139 Re: Some more top swap questions! Yay!
    Donating Users timboku's Avatar
    Montgomery, IL
    If it's a complete l67, grab it, all the parts you need for a top swap will be fine, them you have all the pullies, bolts, etc...then scrape the block for 20bucks
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  20. #140 Re: Some more top swap questions! Yay!
    Oct 2015
    Well its complete except the pulleys are already off it and the supercharger, tb, and all that stuff up top is off but i already have a sc. Basically it has everything lim and down including coil pack bracket with coil packs
  1. top swap questions
    By 1976beef in forum Introductions/Noob Questions
    Last Post: 10-31-2015, 05:58 PM
  2. e85 swap questions
    By 04lss in forum Introductions/Noob Questions
    Last Post: 09-30-2014, 03:13 PM
  3. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  4. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
