Thread: Some more top swap questions! Yay!
Page 18 of 71 FirstFirst ... 816171819202868 ... LastLast
Results 341 to 360 of 1411
  1. #1 Re: Some more top swap questions! Yay!
    its best to mod the n/a pcm. trans settings are not the same for one.
  2. #2 Re: Some more top swap questions! Yay!
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Okay then canned tune to start it is. Ive been talking to reptile about getting one of his tunes but i havent heard from him in a couple days so i know everyone hates zzp but is intense or wbody any good?
    Sent from my LG-D851 using Tapatalk
  3. #3 Re: Some more top swap questions! Yay!
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Quote Originally Posted by suitercrew View Post
    Give Reptile a few more days. He isn't very active. It took him awhile to reply to one of my PM's.
  4. #4 Re: Some more top swap questions! Yay!
    Bastard Reptile's Avatar
    Kansas City, MO
    Huh? You were supposed to let me know when you were ready to send payment.....I've been waiting on you.
  5. #5 Re: Some more top swap questions! Yay!
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    Scotty do you know what a L36 N/A cam lift is? Are the L36 and L67 cams the same? How much lift do like 1.95 rockers that you have end up being?
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  6. #6 Re: Some more top swap questions! Yay!
    the cam is the same. no idea on the new specs with rockers on.
  7. #7 Re: Some more top swap questions! Yay!
    Kemmerer, Wyoming
    a cam will make about 40 more hp, while a set of high ratio roller rockers will make about 20 more hp. if I was going to do it all over, I would use a cam designed by will from overkill motorsports. he designed a stock blower cam and a big blower cam. the stock blower cam can be paired with 1.7 ratio rockers for more lift and uses the 90 lb LS6 valvesprings so no double roller timing chain is necessary.
    http://www.getoverkilled.ca/3800tech.html
  8. #8 Re: Some more top swap questions! Yay!
    Oct 2015
    Do you know the price on that sbc? I didnt want to do a cam cause i didnt want to have to spend all the extra money on a double roller, lifters, pushrods etc but if i can use all stock internals minus the l76 springs i already have and a new stock timing chain setup which i should probably do anyway since i have 100xxx id kinda ve interested
  9. #9 Re: Some more top swap questions! Yay!
    Kemmerer, Wyoming
    you have to contact comp cams to get the cam built as overkill does not stock the cam himself. I imagine it would be about 325. I would just call comp cams and give them the grind number specified on overkill's website.
  10. #10 Re: Some more top swap questions! Yay!
    Oct 2015
    Is it normal to have to bend the crossover pipe on sd headers to get them to fit right i finally got them and all the bolts line up perfect but i put them together and it doesnt appear like things will line up very well currently
  11. #11 Re: Some more top swap questions! Yay!
    Oct 2015
  12. #12 Re: Some more top swap questions! Yay!
    twist the crossover pipe should square em up.
  13. #13 Re: Some more top swap questions! Yay!
    Oct 2015
    Ya after playing with the puzzle i got them pretty close to where i think they should be they might be off a little still but i guess i just have to be patient and wait to find out haha. Also i got a front o2 extension and since the dp has the plug for tge reare o2 i will probably just run it 100% legal in which case do i also need a rear o2 extension? It looks to be almost in the same place as stock but so does the front o2
  14. #14 Re: Some more top swap questions! Yay!
    rear o2 still reaches. same place.
  15. #15 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok thanks scotty!!
  16. #16 Re: Some more top swap questions! Yay!
    Oct 2015
    I replied to you days ago i dont know what happened then. Pm me your paypal and ill try to send it tonight
  17. #17 Re: Some more top swap questions! Yay!
    Kemmerer, Wyoming
    I've always had good luck doing business with reptile. He has always been true to his word for me.
  18. #18 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok so quick question about the sc vac lines i think i have ot figured out so the little nipple on the front of the lim has to connect to the fpr and the map, i dont have the preessure control selonoid but thats ok cause i just leave the bbv open to atmosphere. The top nipple on bbv goes to the tree and the brake booster hose and the other one goes to the tree also correct?
  19. #19 Re: Some more top swap questions! Yay!
    un marked 3 rd nipple goes to the back line off the fire wall. its the one next to your brake booster line now on the upper intake of the n/a set up.
  20. #20 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok so i dont need the by pass solenoid correct just leave the actuator open to atmosphere. Also do you know what size vacc lines ill need?
  1. top swap questions
    By 1976beef in forum Introductions/Noob Questions
    Last Post: 10-31-2015, 05:58 PM
  2. e85 swap questions
    By 04lss in forum Introductions/Noob Questions
    Last Post: 09-30-2014, 03:13 PM
  3. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  4. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
