Thread: Some more top swap questions! Yay!
Page 58 of 71 FirstFirst ... 848565758596068 ... LastLast
Results 1,141 to 1,160 of 1411
  1. #1141 Re: Some more top swap questions! Yay!
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Ya im gonna get over to my dads either tomorow or thursday he has a teste
    Sent from my LG-D851 using Tapatalk
  2. #1142 Re: Some more top swap questions! Yay!
    Oct 2015
    Dont missfires usually happen when under load?
  3. #1143 Re: Some more top swap questions! Yay!
    Bastard Reptile's Avatar
    Kansas City, MO
    I've never seen that code before....might be wiring?
  4. #1144 Re: Some more top swap questions! Yay!
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    No alot of the time is during idle and will clear up when you give it throttle. Remember that picture of that bent rod I showed you when my motor hydro locked when it was N/A? Well I'm not saying you have the same problem but I did what your doing I changed everythingggg then I did a compression test and it was low in cylinder 5 I didn't find the issue untill obviously when I pulled the motor and gutted it but the misfire wasn't even hardly noticeable and if any it was during idle like your car the only reason I knew it was misfiring is because it was throwing a code.
    Sent from my SM-G920V using Tapatalk
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  5. #1145 Re: Some more top swap questions! Yay!
    Oct 2015
    Well do you really even need to mess with it if its not noticeable?
  6. #1146 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    Lol dude I had a bent rod... it would have blown up if I drove it and hammered on it are you crazy? Then the block and everything would have been junk
  7. #1147 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    If something major is wrong which I'm leaning towards that considering you changed everything else you can end up with a bigger paper weight then what you have not even trying to sound like a ass hole I'm being honest don't F it up more then it is by driving it untill you figure out what's wrong
  8. #1148 Re: Some more top swap questions! Yay!
    Oct 2015
    Ya i get that but really i havent looked in what all it would take to rebuild the bottom end but im pretty sure you could just buy a used motor for cheaper if thats what you were going to have to do
  9. #1149 Re: Some more top swap questions! Yay!
    Oct 2015
    Well see what the compression tests say if i had money on anything id say the valves werent seating properly as of right now i dont have any signs of a blown piston or piston ring
  10. #1150 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    Yeah hopefully it's the valve I don't feel like it's the rings I'd say chipped piston or valves the fact that you had 4° of kr and your running lean makes it seem more of like a chipped piston to me it could be a really small hole
  11. #1151 Re: Some more top swap questions! Yay!
    Oct 2015
    Ill take fd up valves all day if thats my options lol. Just out of curiosity how hard is it to replace a piston?
  12. #1152 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    Take it somewhere don't do it yourself it's not something you should be doing if you never done it before. If it is the piston I'd change them all and put new rings in at the minimum it's dumb not to
  13. #1153 Re: Some more top swap questions! Yay!
    May 2012
    Where winter never ends
    Stickied this to send newbs her to read all this awesome info! Proceed.
    2000 Regal - Winter Beater
  14. #1154 Re: Some more top swap questions! Yay!
    Quote Originally Posted by suitercrew View Post
    its not a piston. and you dont just change one.
  15. #1155 Re: Some more top swap questions! Yay!
    May 2012
    You dont on a 3800 unless you have one hell of a machine shop sitting in your shed. From what I recall, 3800 cranks wear in an egg shaped style, add a perfectly round new rod to that and you have a spun bearing a week later. Just a piston maybe, but generally people just go to the Jy and buy a motor lol. I went through 3 of them
  16. #1156 Re: Some more top swap questions! Yay!
    Oct 2015
    Quote Originally Posted by Tonkin2000GT View Post
    So if u were to take it somewhere i would dfeffinately assume the price would be crazy expensive and id be better off buying a used l67 and not having to worry about compression.
  17. #1157 Re: Some more top swap questions! Yay!
    May 2012
    Yep, buy a JY motor and go to town.
  18. #1158 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    Yeah but the problem with that is you could end up with problems like you said you can't find a motor with less then 200,000 miles F that if you build your own you know it's brand new and you should never have to worry about it. Make some phone calls get a estimate it's not as much as you think if do most of the manual labor normal crap yourself.
  19. #1159 Re: Some more top swap questions! Yay!
    May 2012
    I know of at least 3 hell stories of people going to local shops to get motors done and coming out with a spun bearing or tossed rod in a few weeks. It's just easier to get a JY motor and be happy. I made 550+ on a 160k mile motor. Unless you are going for some insane build, its more economical to just go JY
  20. #1160 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    Yeah where is this? Some back yard mechanic? The problem is trying to find our motors with lower miles even then your still going to want to go through it and change gaskets while it's in front of you.
  1. top swap questions
    By 1976beef in forum Introductions/Noob Questions
    Last Post: 10-31-2015, 05:58 PM
  2. e85 swap questions
    By 04lss in forum Introductions/Noob Questions
    Last Post: 09-30-2014, 03:13 PM
  3. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  4. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
