Thread: Some more top swap questions! Yay!
Page 10 of 71 FirstFirst ... 891011122060 ... LastLast
Results 181 to 200 of 1411
  1. #181 Re: Some more top swap questions! Yay!
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Sent from my LG-D851 using Tapatalk
  2. #182 Re: Some more top swap questions! Yay!
    Oct 2015
    Should i get new valve spring retainers and locks or just call it good if they look good. I was planning on just replacing valve seals is that good?
  3. #183 Re: Some more top swap questions! Yay!
    just the seals. unless you upgrade the springs, then you need new retainers for the springs. the locks,/keepers re use.
  4. #184 Re: Some more top swap questions! Yay!
    Oct 2015
    So if i got some 90# springs from wbody store im pretty sure it says you can reuse the stock retainers so is it a you really should swap them if you get any kind if stiffer spring or only if the new spring requires new retainers?
  5. #185 Re: Some more top swap questions! Yay!
    You need to get ls style retainer. Now the locks can be reused but it's better to grab some because there's a good chance that you'll lose one.
    04 Comp G.
  6. #186 Re: Some more top swap questions! Yay!
    pretty sure if you get ls springs you need the retainer for that spring. they are a larger spring in everyway.
    i got my rocker and springs and all as one unit, was told to use the new retainers that came with the rocker set.
  7. #187 Re: Some more top swap questions! Yay!
    Oct 2015
    Hmm okay well thanks for the help!
  8. #188 Re: Some more top swap questions! Yay!
    Oct 2015
    Also the sd headers bolt onto the stock 2.25 catback right?
  9. #189 Re: Some more top swap questions! Yay!
    Yup
    04 Comp G.
  10. #190 Re: Some more top swap questions! Yay!
    yes.
  11. #191 Re: Some more top swap questions! Yay!
    Oct 2015
    Quick question do rockers or a cam help with kr?
  12. #192 Re: Some more top swap questions! Yay!
    both help. cam is the better choice tho, but is more work.
  13. #193 Re: Some more top swap questions! Yay!
    Oct 2015
    Ya cam is a lot more work but maybe you guys can give some adivce my goal is 300chp i figured with a top swap and headers id be around 260 and if i got some 1.9s and could run a 3.6 id be at right around 290 which would be good enough for me. Suggestions?
  14. #194 Re: Some more top swap questions! Yay!
    im top swapped. fsic, 3.0 pulley, 42 injectors, lightly ported heads, 1.95 rockers, headers. its maybe 300 @ the crank. no idea tho. it does feel a ton better.
    a cam gets you to and past 300 whp, intercoolers or e85 help get you there too.
  15. #195 Re: Some more top swap questions! Yay!
    Kemmerer, Wyoming
    A cam makes more power, about 40hp
  16. #196 Re: Some more top swap questions! Yay!
    Oct 2015
    So if i did a cam with my headers on my top swap its likely id also be able to pulley down to a 3.6 or so? Also i hear how driveability can be bad with a cam but i dont understand qhat that exactly means.
  17. #197 Re: Some more top swap questions! Yay!
    3.4 for sure. maybe a 3.3 with a larger cam.
    if they mean traction issues, check, i got them already lol
  18. #198 Re: Some more top swap questions! Yay!
    Kemmerer, Wyoming
    Cam doesn't change drive ability. My xp cam drives like it did when it was stock, except when the pedal is mashed
  19. #199 Re: Some more top swap questions! Yay!
    Oct 2015
    I think im just gonna stick with rockers i researched doing a cam and it was pretty hardcore for my mechanical level haha
  20. #200 Re: Some more top swap questions! Yay!
    Kemmerer, Wyoming
    like I said earlier, the hardest part of doing a cam is getting the harmonic balancer off. with the balancer off, taking the timing cover off is easy, something like 10 bolts, then take the timing chain off and then take out the cam.
  1. top swap questions
    By 1976beef in forum Introductions/Noob Questions
    Last Post: 10-31-2015, 05:58 PM
  2. e85 swap questions
    By 04lss in forum Introductions/Noob Questions
    Last Post: 09-30-2014, 03:13 PM
  3. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  4. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
