Yup because..........
^^^^^^INTERCOOLERS SUCK ON AN M90 that is all............
And Ill keep saying it in every single thread I find that's related to 2.8, & E85......
Its almost like I get an alert when people talk about intercoolers.... HAHA
Im just here to set the record straight.
If you can use E85 use it!! Then if you truly insist on a damn Intercooler be my guest.
Let me know when
A it doesn't seal
B the car doesn't run right
C your mad because you have to move other items to make it fit.
D Pump fails
E core is leaking coolant in your LIM
F lines leak
G front mount heat exchanger gets smashed or leaks
H sick of the issues yet? Told you so....
I oh almost forgot youll need big buck fuel logs or run some hacked up modded fuel lines
