Thread: stage 3 heads or is aluminum worth the price?
Results 1 to 20 of 25
Golgo13 stage 3 heads or is aluminum... 12-18-2014, 12:05 AM
16MustangVet Re: stage 3 heads or is... 12-18-2014, 01:20 AM
selliott Re: stage 3 heads or is... 12-18-2014, 02:21 AM
DanPrixGTP Re: stage 3 heads or is... 12-18-2014, 03:09 AM
SgtMarshal Re: stage 3 heads or is... 12-18-2014, 08:41 AM
Turbocharged400sbc Re: stage 3 heads or is... 12-18-2014, 09:18 AM
Bio248 Re: stage 3 heads or is... 12-18-2014, 09:22 AM
Turbocharged400sbc Re: stage 3 heads or is... 12-18-2014, 09:34 AM
blueguy Re: stage 3 heads or is... 12-18-2014, 10:41 AM
jdredd Re: stage 3 heads or is... 12-18-2014, 03:09 PM
Bio248 Re: stage 3 heads or is... 12-18-2014, 09:42 AM
GTPpower Re: stage 3 heads or is... 12-18-2014, 10:50 AM
blueguy Re: stage 3 heads or is... 12-18-2014, 11:11 AM
Sven the Sexman Re: stage 3 heads or is... 12-18-2014, 11:13 AM
Turbocharged400sbc Re: stage 3 heads or is... 12-18-2014, 11:21 AM
Sven the Sexman Re: stage 3 heads or is... 12-18-2014, 11:24 AM
Turbocharged400sbc Re: stage 3 heads or is... 12-18-2014, 11:34 AM
Sven the Sexman Re: stage 3 heads or is... 12-18-2014, 11:49 AM
MrPoopyButthole Re: stage 3 heads or is... 12-18-2014, 11:57 AM
Sven the Sexman Re: stage 3 heads or is... 12-18-2014, 12:05 PM
Bio248 Re: stage 3 heads or is... 12-18-2014, 11:46 AM
MrPoopyButthole Re: stage 3 heads or is... 12-18-2014, 11:54 AM
blueguy Re: stage 3 heads or is... 12-18-2014, 12:15 PM
16MustangVet Re: stage 3 heads or is... 12-18-2014, 03:16 PM
jdredd Re: stage 3 heads or is... 12-18-2014, 04:06 PM
  1. #1 stage 3 heads or is aluminum worth the price?
    Oct 2008
    mascoutah, Il
    Starting a new build on a CompG and was just wondering what is the difference in buying the stage 3 head and cam kit from intense opposed to buying the aluminum heads xpz cam from zzp?
    I was set on the aluminum heads until I noticed the price difference between intense racings price for their stage 3 kit and zzps price for everything I need for their aluminum heads and xpz cam. The overall price isn't that much of an issue I just don't want to waste money going thru zzp if the outcome doesn't have that big of a difference from what I can get out of the intense kit.
    2002 GTP
    custom HOK paint
  2. #2 Re: stage 3 heads or is aluminum worth the price?
    alum is more of a look what i have imo. dont get me wrong id love to have a set but at the same time its a tough pill to swallow given the price difference of the s3 iron heads.
    just my 2c
  3. #3 Re: stage 3 heads or is aluminum worth the price?
    I break stuff selliott's Avatar
    Kansas City
    I have intense s4 heads, no complaints so far
  4. #4 Re: stage 3 heads or is aluminum worth the price?
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Is anyone actually running the Aluminum heads? I feel like it's a rare sight to see.
    Obviously aluminum has much quicker heat dissipation compared to iron, which is very helpful. But the majority of builds wouldn't even require aluminum heads for the 3800, I wouldn't think.
    Buying Intense Stage 3/4 heads will be most likely be more than enough and a better way to spend your money. The aluminum heads would be great to have, but it would be more of a "wow" factor by having them, and something to brag about and just be able to say you have aluminum heads.
    * As a side note, Chris Hinson (OrangeL67 on this forum) does port/polishing on heads. Easily the best work done by anyone. The guy knows his stuff. His "Stage 4" heads have out-flowed Intense's Stage 4 Heads. He has CFM numbers to prove it. Pretty impressive. Send him a message on here / facebook / or email if your interested. His work is better and cheaper than a vendor.
    http://www.grandprixforums.net/threa...-P-amp-P-Heads
  5. #5 Re: stage 3 heads or is aluminum worth the price?
    Kemmerer, Wyoming
    aluminium heads will let you run more compression without increasing the required octane rating of your fuel. my in laws are big into the small block 350 and on the big hp builds they pretty much always have aluminium heads.
    with that said, you will likely get more bang for your buck if you get a set of heads ported by Chris Hinson.
    https://www.facebook.com/cjhinson?fref=ts
    http://www.grandprixforums.net/members/9966-OrangeL67
  6. #6 Re: stage 3 heads or is aluminum worth the price?
    hangover park IL
    far more bang for the buck with stock heads and a turbo kit.
    m90 sucks
    ~James~ Psychotic Gearhead
  7. #7 Re: stage 3 heads or is aluminum worth the price?
    while i agree the m90 is terrible....
    there's no such thing as a big, lopey turbo cam. blower cams? oh yeah.
    the car will never be exceptionally fast anyway...might as well make it sound badass.
  8. #8 Re: stage 3 heads or is aluminum worth the price?
    hangover park IL
    i love how many of the "big cam" turbo builds make less power than our tiny duration cam
  9. #9 Re: stage 3 heads or is aluminum worth the price?
    Quote Originally Posted by Turbocharged400sbc View Post
    I built mine to sound cool.
    And shake and break everything.
    And it did that.
    And probably only made 202WHP.
    But I agree, snail all the way. I'll never build anything Eaton powered ever again.
  10. #10 Re: stage 3 heads or is aluminum worth the price?
    Nov 2012
    Erlanger, KY
    the converter locking used between all parties?
    M90 car, from zzp s3 to aluminum heads, had zero gains to be noticed. Almost full weight running low 11.6x's... after the fact.. high 11.5x ... and it was
    hard to tell if it was down to tune or launch, ect.. either way, to me wasn't worth it for performance. Weight drop is nice, but really need to drop hundreds of
    pounds to start getting big gains. 35lbs off a heavy car.. not gonna see much.
    Only good thing, is when a L26 engine we strapped em to blew 2 pistons out the sides on 2nd run, the heads were able to be repaired and look like new again.
    That this is a nice plus. Easy to get repaired.
    2001 Turdbo Grand Prix GTP - 10.41@132
    Videos @ https://www.youtube.com/user/jdredd34
  11. #11 Re: stage 3 heads or is aluminum worth the price?
    if i were building another wbody i'd leave the m90 and run a big cam/heads setup and whatever is the smallest pulley i could run on stock timing.
    it'd be quick and sound cool. it'd also stay within a decently sized budget...
  12. #12 Re: stage 3 heads or is aluminum worth the price?
    May 2008
    Schuyler, NE
    Intense heads suck. I have all kinds of pics to prove it.
    Zzp's stage 4 iron heads outflow aluminum heads. You have to have the aluminum heads ported to get extra flow over a stock cast head.
  13. #13 Re: stage 3 heads or is aluminum worth the price?
    The alummy heads were a solid idea, just weren't executed correctly for the money that they wanted for them.
  14. #14 Re: stage 3 heads or is aluminum worth the price?
    Mar 2012
    NC
    Stage 4 heads + reverse flow cooling FTW.
  15. #15 Re: stage 3 heads or is aluminum worth the price?
    hangover park IL
    reverse flow cooling on our cars is impossible without a divorced electric fuel pump and a good bit of work
  16. #16 Re: stage 3 heads or is aluminum worth the price?
    Mar 2012
    NC
    Exactly...but if you're going all out spending redonkilous amounts of monies for such things, you might as well do it.
  17. #17 Re: stage 3 heads or is aluminum worth the price?
    hangover park IL
    if your going that far why would you stick with the ****ty short deck SII?
  18. #18 Re: stage 3 heads or is aluminum worth the price?
    Mar 2012
    NC
    Tall deck pre-series 3800 was indestructible.
  19. #19 Re: stage 3 heads or is aluminum worth the price?
    B234r 4 lyfe!
  20. #20 Re: stage 3 heads or is aluminum worth the price?
    Mar 2012
    NC
    Quote Originally Posted by dRunK13 View Post
    B234r 4 lyfe!
    That's not a real engine...Saabs only come with hamster wheels attached to the trans.
  1. worth the price
    By Mirraco in forum General Grand Prix Discussion
    Last Post: 09-09-2014, 08:13 PM
  2. stage 2 IC or heads
    By JoeyGTP in forum Wanted To Buy - Parts
    Last Post: 12-28-2013, 05:05 PM
  3. ZZP aluminum heads
    By Sabrewings in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-15-2008, 08:28 PM
