Thread: running a 3.25" pulley
Results 1 to 20 of 22
  1. #1 running a 3.25" pulley
    SE Level Member CompCam21's Avatar
    chicago
    I have been following the thread about the ebay headers and want to buy them in the next day or so. I am not going to need a tune to run these headers correct? From my understanding these are just simple bolt on mods but please correct me if i am wrong. My goal is to run an 3.25" pulley and i have about 500 bucks now to start modding so i want to do that correctly. I plan on the headers, new colder spark plugs, wires, 180 t-stat, and FWI. Will those be enough mods to not have too much KR with a 3.25" pulley. Now, about KR, how do i measure how many degrees i have? Do i have to buy a scanner of some sort. If it makes any difference i work at a honda dealership so would they have any scanners i could use? and lastly, how do i go about getting my pcm tuned, that is, who is good, can i do it myself, etc.
  2. #2 Re: running a 3.25" pulley
    GTX Level Member real diehl's Avatar
    Salina, KS
    No ZZP tunes...
    for the sake of your car
    signature removed for inappropriate content.
    -bio
  3. #3 Re: running a 3.25" pulley
    chicago
    yes that is what i have herd
  4. #4 Re: running a 3.25" pulley
    in a house
    Quote Originally Posted by CompCam21 View Post
    You should really invest in a scanner like an Aeroforce so you can keep on eye on things all the time. No one can say whether or not you can run a 3.25 with the mods you listed. I highly doubt you can safely. You may want to add rockers and/or an intercooler to that list. As far as a tune try to find someone close to you that can tune it.
  5. #5 Re: running a 3.25" pulley
    not enough to run a 3.25 with any good amount of timing. stick with a 3.4 for now, if youd have rockers you could run the 3.25 MAYBE.
  6. #6 Re: running a 3.25" pulley
    A decent cam would put you in the 3.25" pulley range perhaps.
    an I/C would put you at 3"
  7. #7 Re: running a 3.25" pulley
    And then blow up your car when your injectors run static
  8. #8 Re: running a 3.25" pulley
    Yup, Perma-lean.
    Honestly, safely 3800 thread topic again.
  9. #9 Re: running a 3.25" pulley
    in a house
    Yup, Perma-lean.
    Are you reminding yourself to read it?
  10. #10 Re: running a 3.25" pulley
    Quote Originally Posted by silverstreak View Post
    Its been one of those days...
  11. #11 Re: running a 3.25" pulley
    chicago
    yea i wasnt sure if i was being a little to optimistic in hopeing that i could run a 3.25 with the mods i plan. i will just plan on running a 3.4 because i just want some more performance without having to blow to much coin...if it would take rockers or intercooling or camming it out to get to a 3.25 than that is a little more than i want to get into for now...it is my dd while i am in college so i just want it to be a little more fun till i get out of school nd can buy something i really want. Is it possible to do the mods i plan with the 3.4 for around 500 bucks?
  12. #12 Re: running a 3.25" pulley
    Quote Originally Posted by compcam21 View Post
    is it possible to do the mods i plan with the 3.4 for around 500 bucks?
    maybe.
  13. #13 Re: running a 3.25" pulley
    chicago
    hahaha that was what i was thinking too
  14. #14 Re: running a 3.25" pulley
    Topeka, KS
    I'm running a 3.25 with the following mods.
    Custom HP Tuners Tune by Green Bastard Performance
    Intense Modular Supercharger Pulley System 3.4, 3.25 (3.25 Currently Installed)
    Custom Magnaflow Exhaust
    Denso Lead Tolerant 02 sensor
    ZZP Red Poly Dogbone Engine Mounts
    Autolite 104's
    Hypertech 180* Thermostat
    Fender well Intake (Homemade)
    Green Bastard Performance Ported Supercharger
    Green Bastard Performance Ported Throttle Body
    SS Autochrome Headers with 1-3/4" Primary's and 3" Down-Pipe
    Currently only seeing 1.4* of KR but i believe it can be tuned out. If not i'll mod some more until i achieve 0* of KR.
    I think the ported TB & Supercharger helped me to be able to get down to the 3.25 pulley. Do all of the things you have planned above and you can definitely achieve the 3.4" you just gotta see how your car reacts to get smaller. Every car acts different to modifications.
  15. #15 Re: running a 3.25" pulley
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Quote Originally Posted by rynoman03 View Post
    Autolite 104's
    What is your timing set at?
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  16. #16 Re: running a 3.25" pulley
    Autolite 104's
    get a set of rockers and i bet youll be at your goal.
    Quote Originally Posted by JoshMcMadMac View Post
    im thinking stock (16*).
  17. #17 Re: running a 3.25" pulley
    chicago
    thanks for all the help...however, no one addressed the issue if i am going to need a tune for the headers...which i am certain i dont but i just want to cover my bases....i am probably going to get the headers before i throw on a smaller pulley.
  18. #18 Re: running a 3.25" pulley
    Charles City, IA
    No get a tune during the pulley drop.
    SMGPFC Two Nipple General
  19. #19 Re: running a 3.25" pulley
    no tune needed for the headers, but one's needed/recommended for the pulley drop.
  20. #20 Re: running a 3.25" pulley
    Charles City, IA
    ^ I win!
  1. 3.5" tuned PCM running on 3.8" engine
    By 04CompG in forum PCM Tuning
    Last Post: 10-06-2008, 05:14 PM
