Thread: Running a 2.8 pulley on an uncooled l67 on e85
Results 1 to 20 of 55
Threaded View
  1. #11 Re: Running a 2.8 pulley on an uncooled l67 on e85
    Quote Originally Posted by wa04compg View Post
    ^everything you post has to do with e85 and your dyno numbers hahaha
    Yup because..........
    ^^^^^^INTERCOOLERS SUCK ON AN M90 that is all............
    And Ill keep saying it in every single thread I find that's related to 2.8, & E85......
    Its almost like I get an alert when people talk about intercoolers.... HAHA
    Im just here to set the record straight.
    If you can use E85 use it!! Then if you truly insist on a damn Intercooler be my guest.
    Let me know when
    A it doesn't seal
    B the car doesn't run right
    C your mad because you have to move other items to make it fit.
    D Pump fails
    E core is leaking coolant in your LIM
    F lines leak
    G front mount heat exchanger gets smashed or leaks
    H sick of the issues yet? Told you so....
    I oh almost forgot youll need big buck fuel logs or run some hacked up modded fuel lines
  1. What to look for when running a smaller pulley
    By tweeder in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-25-2014, 07:38 PM
  2. engine running hot after a/c copressor taken out and replaced with bypass pulley
    By ronniemarcus in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-15-2013, 10:12 AM
  3. Currently Running 3.4 Pulley - Want to go 3.3
    By Spaceghost in forum General Tech Discussion
    Last Post: 08-17-2011, 06:30 AM
  4. How Long Have You Been Running A Smaller Pulley?
    By SliceTheRice in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-27-2010, 09:13 AM
  5. running a 3.25" pulley
    By CompCam21 in forum General Tech Discussion
    Last Post: 01-30-2010, 05:33 PM
