Hold down both buttons/knobs until the climate control display shows 00.
Then you can turn the driver side knob to 12. Then turn the passenger side one click.
This will show you the engine coolant temp minus 60 degrees. Not sure why there is a 60 degree offset, but there is. If your temp is 200, then it will read 140 and so forth.
