Thread: Having trouble bleeding the cooling system
Page 1 of 3 123 LastLast
Results 1 to 20 of 54
  1. #1 Having trouble bleeding the cooling system
    SE Level Member LHRxXD3adXx's Avatar
    Oct 2014
    Hello guys have any of you guys had trouble bleeding the cooling system before? When i put a thermostat in it dosent want to open up and i know it works. My fans kick on and it blows hot but the car overheats. If i run without the t stat it runs fine.
  2. #2 Re: Having trouble bleeding the cooling system
    Pull the t stat out, fill through that hole. Put it back together, top off the rad and you'll be good in minutes
  3. #3 Re: Having trouble bleeding the cooling system
    Oct 2014
    Ive done that. But the car keeps getting hot. Almost on the red mark
  4. #4 Re: Having trouble bleeding the cooling system
    Put the thermostat in a pot of boiling water and watch for it to open. Might be defective
  5. #5 Re: Having trouble bleeding the cooling system
    Oct 2014
    Its works i have 5 that ive bought already and they all work tested them together they are all different temperatures. And they all opened according to their rating
  6. #6 Re: Having trouble bleeding the cooling system
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Or just buy a new thermostat for $5 and go from there.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  7. #7 Re: Having trouble bleeding the cooling system
    could be a shot to hell water pump impeller. take the t stat out, put the housing back on with the hose on it, then take the upper hose off the rad, start the car, coolant should pump out the top hose. if it dont the water pump is dead, or somethings real clogged up.
  8. #8 Re: Having trouble bleeding the cooling system
    Oct 2014
    Also got a new tempeture sensor but who know maybe it not accurate? I know the car runs a little hot with out the t stat but not to the point were is almost in red
  9. #9 Re: Having trouble bleeding the cooling system
    Knoxville, TN
    Is it possible to install the T-stat upside down? Not sure if that would make any difference anyway.
    You can also try bleeding the system with the bleeder screw on top of the t-stat housing.
    Another option, drill a small hole or two in the thermostat to allow air to escape.
  10. #10 Re: Having trouble bleeding the cooling system
    Quote Originally Posted by LHRxXD3adXx View Post
    if it hits the red with no t stat you got a clogged rad, or a dead pump.
  11. #11 Re: Having trouble bleeding the cooling system
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    If the radiator is blowing hot and the fans are kicking in its not a thermostat or trapped air issue. Check the actual temperature with a infa red thermometer or something. My guess is everything is working fine but your coolant temp sensor is bad.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  12. #12 Re: Having trouble bleeding the cooling system
    Oct 2014
    Water pump is new and engine just had a full rebuild. When the t stat is out and i put my spill free funnel on the radiator i can see the antifreeze go down as i rev the engine so i know there is circulation
  13. #13 Re: Having trouble bleeding the cooling system
    you have a torque app? use that to see what the temp is. if you have one.
  14. #14 Re: Having trouble bleeding the cooling system
    Oct 2014
    Quote Originally Posted by GTP131 View Post
    You cant put it upside down. But drilling 2 small holes is not a bad idea
  15. #15 Re: Having trouble bleeding the cooling system
    Oct 2014
    No i dont. But i can get one if there not expensive
  16. #16 Re: Having trouble bleeding the cooling system
    if you have a droid phone its 5$ for the app, and like 10 to $12 for the obd2 blue tooth adapter on ebay.
    that temp sensor has two signals, one to the fans, one to the pcm. even new they can be bad. seen it happen a lot here. one guy it took 3 new ones till it worked right.
  17. #17 Re: Having trouble bleeding the cooling system
    Knoxville, TN
    What year is the car? If it has the dual digital climate control for certain years, you can use that to see engine coolant temperature.
  18. #18 Re: Having trouble bleeding the cooling system
    I have seen an air pocket cause these cars to get hot.
  19. #19 Re: Having trouble bleeding the cooling system
    Oct 2014
    Ok yea i know what it is. Wont it be the same if i just hook up my scanner and go to my live data? But my question is that if the sensor is bad isn't it going to give me the wrong readings?
  20. #20 Re: Having trouble bleeding the cooling system
    Oct 2014
    98 how can i do that?
  1. Cooling system help
    By 2006GrandPrixGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-06-2014, 01:59 PM
  2. Bleeding PS system?
    By atomicjoe23 in forum Brakes/Suspension/Chassis
    Last Post: 07-30-2012, 10:42 PM
  3. need help with bleeding coolant system
    By loganrick in forum Engine
    Last Post: 12-26-2011, 01:10 PM
  4. Cooling System
    By kcfalcon2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-30-2011, 01:44 PM
