Thread: Having trouble bleeding the cooling system
Results 1 to 20 of 54
  1. #1 Re: Having trouble bleeding the cooling system
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Is it possible to install the T-stat upside down? Not sure if that would make any difference anyway.
    You can also try bleeding the system with the bleeder screw on top of the t-stat housing.
    Another option, drill a small hole or two in the thermostat to allow air to escape.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  2. #2 Re: Having trouble bleeding the cooling system
    SE Level Member LHRxXD3adXx's Avatar
    Oct 2014
    Quote Originally Posted by GTP131 View Post
    You cant put it upside down. But drilling 2 small holes is not a bad idea
  1. Cooling system help
    By 2006GrandPrixGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-06-2014, 01:59 PM
  2. Bleeding PS system?
    By atomicjoe23 in forum Brakes/Suspension/Chassis
    Last Post: 07-30-2012, 10:42 PM
  3. need help with bleeding coolant system
    By loganrick in forum Engine
    Last Post: 12-26-2011, 01:10 PM
  4. Cooling System
    By kcfalcon2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-30-2011, 01:44 PM
