Thread: Having trouble bleeding the cooling system
Results 1 to 20 of 54
  1. #1 Re: Having trouble bleeding the cooling system
    could be a shot to hell water pump impeller. take the t stat out, put the housing back on with the hose on it, then take the upper hose off the rad, start the car, coolant should pump out the top hose. if it dont the water pump is dead, or somethings real clogged up.
  2. #2 Re: Having trouble bleeding the cooling system
    SE Level Member LHRxXD3adXx's Avatar
    Oct 2014
    Water pump is new and engine just had a full rebuild. When the t stat is out and i put my spill free funnel on the radiator i can see the antifreeze go down as i rev the engine so i know there is circulation
  1. Cooling system help
    By 2006GrandPrixGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-06-2014, 01:59 PM
  2. Bleeding PS system?
    By atomicjoe23 in forum Brakes/Suspension/Chassis
    Last Post: 07-30-2012, 10:42 PM
  3. need help with bleeding coolant system
    By loganrick in forum Engine
    Last Post: 12-26-2011, 01:10 PM
  4. Cooling System
    By kcfalcon2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-30-2011, 01:44 PM
