Thread: Evap System
Results 1 to 20 of 28
  1. #1 Evap System
    GT Level Member Flip97GTP's Avatar
    May 2013
    Ft. Lauderdale, Florida
    In my ride, 97 Grand Prix GTP, the evap system is gone. I purchased it like that about a year and half ago, but I got good price for the car. The car runs but not to its full ability. I haven't drove the car for a year or so.
    I was thinking about going to a "you pull it" place this weekend and looking for a Grand Prix and getting a evap system. What years can I take a evap system from and what are the main parts, do I need to take out? Also, photos would help out a lot.
    I appreciate it!
    My 1997 Grand Prix GTP progress build thread!
    Mods At The Moment: 160+ Amps Alternator.
    Mods I Will Be Doing In 2015: Speed Daddy Headers, 3.4" Modular Pulley System, Open Air Intake, BillBoost Tune, TransGo SK® 4T65E Transmission Shift Kit, 180* Thermostat
  2. #2 Re: Evap System
    You'll want a 96-97 Bonneville, Park Ave, Riviera or a 97 Regal/GP
    Get the two dingus's on the back of the motor for evap (Scotty..please insert 97 vac diagram image)
    One is a purge soleniod and the other is a purge valve.
  3. #3 Re: Evap System
    its the check engine light on for the missing evap system? it may have been tunes out if theres no light on for it.
    if you have a code post it up. theres more then just what you see under the hood, theres a canister tank and another solenoid in the rear quarter panel under the gas filler neck. that could be missing too.
  4. #4 Re: Evap System
    May 2013
    Thanks for the diagram that's a big help.
    Yes the check engine light is on. I did a scan on her and these codes come up p0300 and p0441. I think the p0300 code is from my from my fuel pump regulator because the fitting that goes on the nipple dry rotted off.
    I have a thread on this here
    http://www.grandprixforums.net/threa...84#post1069784
  5. #5 Re: Evap System
    http://www.obd-codes.com/p0441 you'll need the vac line from the tb to the solenoids on the back of the engine, then hope you see the other side of the line laying in the rear engine bay somewhere. that line goes to the canister in the back of the car.
    the po300 is multiple misfires you either need a tune up real bad, or the cats clogged up. the cel ever flash when you floor it?
  6. #6 Re: Evap System
    And..keep in mind the switch has a third nipple on the bottom. It should have a L shaped line on it that's maybe 2 inches long and open to air. It's underneath and people always freak about where it goes.... it goes no where
  7. #7 Re: Evap System
    May 2013
    Yes, the CEL comes on when I floor it.
    Billboost, where did you say the fuel pump regulator is?
  8. #8 Re: Evap System
    its listed on that diagram, its on the fuel rail, but thats not your issue at all.
    do buy new vac lines and t's. it will run you 5 bucks tops at the parts store. best T's ive found are at advance auto, 2 t's for 2 bucks, vac line is a buck a foot.
    the t on the middle is the fpr. new t's vac line bbv to map sensor.
  9. #9 Re: Evap System
    May 2013
    I'm sorry, I meant the fuel pressure regulator not the fuel pump regulator. Forget about the fuel pump regulator I check it and its fine.
  10. #10 Re: Evap System
    ahh, the 97, that line would hit that vac tree. you have no t under the snout, that nipple runs to the map sensor. it still worth cahnging the t if its loose or cracked, and any other hard line ends if they are cracked like the t is.
  11. #11 Re: Evap System
    Quote Originally Posted by Flip97GTP View Post
    thats the fpr. its on the fuel rail.
  12. #12 Re: Evap System
    ^^^ Yeah..what he said after he misled!
  13. #13 Re: Evap System
    May 2013
    Thanks Scotty, this helps me out a lot! This is exactly what I was looking for.
  14. #14 Re: Evap System
    97 and that dumb vac tree on the blower. i caught it asap tho and fixed it up.
  15. #15 Re: Evap System
    Technically it was 96 as well.. but that was H/C/G platforms with the S2 and 4T60 combo
  16. #16 Re: Evap System
    May 2013
    Lol...I just found it after a year! I'm glad I found it though. Hopefully everything will work fine when I get it fix up.
  17. #17 Re: Evap System
    May 2013
    I found this hose kit on eBay it's kind of pricey though.
    http://m.ebay.com/itm/380865747379?nav=SEARCH
  18. #18 Re: Evap System
    if you want to spend 80 bucks, go a head. not worth it in my world tho.
  19. #19 Re: Evap System
    May 2013
    Lol...I agree I'm not purchasing that!
  20. #20 Re: Evap System
    May 2013
    I think I'm going to go with the Blue SickSpeed vacuum hoses on eBay. I want to dress her up nice and pretty! Lol
  1. code 0442 Evap system 2001 3.8L
    By chumley in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-11-2013, 12:57 PM
  2. Need Help With Evap system engine code P1665
    By josh22 in forum Introductions/Noob Questions
    Last Post: 01-18-2013, 10:53 PM
  3. Evap system leak in '06 GXP
    By GPGXP06 in forum 5.3L V8 (LS4)
    Last Post: 06-13-2012, 10:30 AM
  4. Deleting EVAP System
    By blueguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-16-2010, 01:48 PM
  5. Problem with the EVAP system
    By victorrleo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2009, 06:10 AM
