does that not happen on all pushrod engines........(contact patch on rocker)When measuring the above rocker using the shiny part as a contact point the rocker ratio varies from 1.53 to 1.81. Pretty crazy huh?
edit: a 1.6 rocker with 257 lobe lift, is still a 1.6 rocker at 300 lobe lift
I did before this and he suggests a whole new kit plus upgrades which the kit alone is like 800 plus performance parts which seems a little too much for me personally.
Also as far as the cam goes LS retainers and 60 injectors good and all that is needed to be safe?
Also should I leave my heads alone or try and do some slight port work on the exhaust side since that is where you have the most gain.
Look at a stock rocker. The higher the cam lift, the longer the distance from pedestal to the tip is.
GTPower is 100% right on this. The lift numbers equate to 1.8 ratios. The deflection that ZZP was seeing does not seem to transfer over into reality, as the 1.7 rockers show decreased power over "stock 1.6s" every time.
Ok guys will be taking out the cam today. In you're opinion should I take the heads to get the valves redone the engine was working 100% but give me the chance to clean up all the piston gunk as well as the heads.
Anything I should watch out for I am going to take off the rockers, pushrods, and lifters then install the cam in with some regular engine oil is that ok? Or do we need special lube to install it.
if it has some miles on it i would consider a valve job, a quick bowl blend with you new cam, yeahhhh!!!!!!
GTPpower, i found this to confirm you knowledge, thank you sir
Rocker Ratio
Well as of now undecided if I should I mean the engine runs great but it has 100k so idk if I should pull them off and get the valves redone or keep them as is as well as try and port them idk if it is difficult to do.
Can I use regular motor oil if not where can I get the assembly lube?
Yeah that is probably what I'll do then when I have the funds get them ported by a shift just enoug to give me some good power nothing crazy. Or I will call around to see f they can do the work don't enlarge to spend past day 3-400 do idl if that is even possible for head wok.
Is there a presence to it a brand or type never bought this stuff before
So as far as the cam goes my only worry is lining up the sits on the gears take the bolt of the cam gear and take the gear off and replace cam put gear back on with the holes lined up and torque it to spec?
| « Previous Thread | Next Thread » |
| Tags for this Thread |
