Thread: VS Cam Build.
Results 1 to 20 of 62
  1. #1 Re: VS Cam Build.
    May 2008
    Schuyler, NE
    Quote Originally Posted by GTP89 View Post
    Well as of now undecided if I should I mean the engine runs great but it has 100k so idk if I should pull them off and get the valves redone or keep them as is as well as try and port them idk if it is difficult to do.
    Can I use regular motor oil if not where can I get the assembly lube?
    I would leave them as is then...but, you will get nowhere near 350whp on stock heads with that cam, FYI.
    I would use assembly lube...any auto parts store will have it.
  2. #2 Re: VS Cam Build.
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    Yeah that is probably what I'll do then when I have the funds get them ported by a shift just enoug to give me some good power nothing crazy. Or I will call around to see f they can do the work don't enlarge to spend past day 3-400 do idl if that is even possible for head wok.
    If You Cant Hear The Whine You're Too Far Behind...
  3. #3 Re: VS Cam Build.
    May 2008
    Schuyler, NE
    It just depends on what they all need.
  4. #4 Re: VS Cam Build.
    Buena Park Ca
    True I mean the heads are fine but I know once taken off those cracks by the valves are common and most shops won't repair them or if they do it is more expensive
  1. ZZP XPZ Build
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2017, 09:40 PM
  2. First ET's with the new build
    By Anthony Smith in forum Track Sessions and Kills
    Last Post: 06-07-2014, 04:16 PM
  3. CSC Build
    By DoubleBlown in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-07-2013, 04:05 PM
  4. Too Slow, Time for a build (GEN V/N*/L32 Lim build)
    By AmericanSoldier in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2012, 01:54 PM
  5. My new build
    By siLversLeigh in forum Members Rides
    Last Post: 02-23-2011, 02:04 AM
