Well as of now undecided if I should I mean the engine runs great but it has 100k so idk if I should pull them off and get the valves redone or keep them as is as well as try and port them idk if it is difficult to do.
Can I use regular motor oil if not where can I get the assembly lube?
Yeah that is probably what I'll do then when I have the funds get them ported by a shift just enoug to give me some good power nothing crazy. Or I will call around to see f they can do the work don't enlarge to spend past day 3-400 do idl if that is even possible for head wok.
