does that not happen on all pushrod engines........(contact patch on rocker)When measuring the above rocker using the shiny part as a contact point the rocker ratio varies from 1.53 to 1.81. Pretty crazy huh?
edit: a 1.6 rocker with 257 lobe lift, is still a 1.6 rocker at 300 lobe lift
