Thread: VS Cam Build.
Results 1 to 20 of 62
  1. #1 Re: VS Cam Build.
    May 2008
    Schuyler, NE
    Quote Originally Posted by GTP89 View Post
    Thanks for the reply
    So is the sonnax upgrade a yes or no are there stages or just one?
    So harden 4th, 4340 IS, 7/8th chain and shift kit good enough?
    Also is this hard to install?
    Talk to Dave. He can get you everything you need. I would buy the valve body from him, as well as his 3rd gear upgrade. Hardened 4th would be good as well.
  2. #2 Re: VS Cam Build.
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    I did before this and he suggests a whole new kit plus upgrades which the kit alone is like 800 plus performance parts which seems a little too much for me personally.
    Also as far as the cam goes LS retainers and 60 injectors good and all that is needed to be safe?
    Also should I leave my heads alone or try and do some slight port work on the exhaust side since that is where you have the most gain.
    If You Cant Hear The Whine You're Too Far Behind...
  3. #3 Re: VS Cam Build.
    May 2008
    Schuyler, NE
    LS retainers and 60lb injectors should be all you need.
    You won't get anywhere close to 350whp on stock heads with a VS cam. If you want those numbers, ported heads are a must.
  1. ZZP XPZ Build
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2017, 09:40 PM
  2. First ET's with the new build
    By Anthony Smith in forum Track Sessions and Kills
    Last Post: 06-07-2014, 04:16 PM
  3. CSC Build
    By DoubleBlown in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-07-2013, 04:05 PM
  4. Too Slow, Time for a build (GEN V/N*/L32 Lim build)
    By AmericanSoldier in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2012, 01:54 PM
  5. My new build
    By siLversLeigh in forum Members Rides
    Last Post: 02-23-2011, 02:04 AM
