yea i know... but it just made me realize how much other stuff was most likely gonna go wrong and that im not equipped to handle it when it does... so i set up an appointment with my mechanic for monday, he's always done good work on my cars so hes gonna do them for me. im not really too good with doing big jobs on my car i guess. i know i can do other things fine but that was too much for me. oh well i guess, now ill just have to deal with my exhaust sounding ****ty until monday![]()
haha too bad your out in jersey... nick (QwikGT) would have helped me but he was working today... id rather just have it done by my mechanic now. hes only like 5 minutes away and i cant drive alot with all the exhaust leaking from my the one side of the crossover pipe where the bolts broke now so thats what im gonna do. car sounds so ****ty right now though, its pissing me off
Try driving around with a open downpipe and a cam...that = FUN![]()
is having exhaust gas from the leaky crossover going into the engine bay really bad for the car? or will i get by until monday?
haha i tried putting some aluminum tape on it to direct the smoke more downwards hopefully...
Idk if this helps but you can get Grade-8 bolts for the headers at Ace hardware. They worked great for mine. Also make sure you use Metal gaskets instead of those paper ones.
I used my old rocker arm bolts for mine, they worked amazingly.
I did the same thing for all four bolts. No more breaking them, and if they do break then I'll just use the spares I got.
test fit:
http://img.photobucket.com/albums/v3...2/DSC02403.jpg
another test fit:
http://img.photobucket.com/albums/v3...2/DSC02402.jpg
and installed:
http://img.photobucket.com/albums/v3...2/DSC02410.jpg
Drill those bishes out
Soak them with PB Blaster or Penetro 90 for a few minutes, then if you have one heat the bolt with a torch and try tapping it out. If you don't have a torch then just soak the bolt and use a punch and hammer to tap the bolt out.
As for the plug wires, try rotating them back and forth while pulling up on them instead of pulling straight off. It's much easier that way.
what is the size and Lenth of the bolts needed to replace the stock one I would like to buy them beforeI start so I will have them
