Thread: GTP Consistent Weird Shift Into Overdrive (4th) Only When In "D"
Results 1 to 20 of 32
  1. #1 Re: GTP Consistent Weird Shift Into Overdrive (4th) Only When In "D"
    It sounds to me like your trans is slipping into OD Take a video of it and we could tell you for sure. Mine used to do that before i got a tune.
  2. #2 Re: GTP Consistent Weird Shift Into Overdrive (4th) Only When In "D"
    Jun 2011
    Minnesota
    That's what I thought at first, but wouldn't it do it when I waited til I got to 50 to put it in drive too then? It's very consistent at only happening when it is in "D" when it hits shifting speed. It doesn't do it at all if I start in 3rd and shift it myself when it gets to 50.
  3. #3 Re: GTP Consistent Weird Shift Into Overdrive (4th) Only When In "D"
    the over drive wont lock up unless you let off the gas some, while in drive
    when in 3 rd and shifting it manually to 4 th it should shift fast and solid, pulling the tach right to where it should be for that speed you are traveling at.
  1. "Perfect Shift" Indicator wont illuminate
    By Grand Prix1 in forum General Tech Discussion
    Last Post: 10-21-2011, 08:03 AM
  2. Occasional shift "clunk" and uneasy acceleration
    By nik12937 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-06-2011, 03:49 PM
  3. Replies: 15
    Last Post: 09-04-2011, 05:25 PM
  4. Weird "creaking?" noise from dash
    By NovoGTP in forum General Tech Discussion
    Last Post: 05-06-2011, 02:04 PM
  5. Feedback/Opinions on the Intense "Shift Kit"?
    By Going Too Phast in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-30-2008, 10:10 PM
