Thread: GTP Consistent Weird Shift Into Overdrive (4th) Only When In "D"
Results 1 to 20 of 32
  1. #1 Re: GTP Consistent Weird Shift Into Overdrive (4th) Only When In "D"
    your regular obd2 scanner wont pick up trans codes, the hi end ones will tho. best to have a trans shop scan it, some charge unless they do the repair work.
    so when it shifts into o/d is it chugging with a rpm fluctuation of 2 to 500 rpm type of thing? that would be a pcs solenoid.
    also if you are in over drive and tap the brakes while still giving it gas, the tach should jump up 200 to 500 rpm as well.
    as far as the shiftier, it may need a new cable or your shiftier itself is taking a slow death. you can always look at where the cable snaps on to on the trans, its right below the master cylinder. make sure its on and not lose or something.
  2. #2 Re: GTP Consistent Weird Shift Into Overdrive (4th) Only When In "D"
    Jun 2011
    Minnesota
    That sounds exactly like what's going on.
    hmm. Maybe I should look at my muffler. I thought the noise was just the loud exhaust cuz none of the mechanics who have looked at it said anything.
  3. #3 Re: GTP Consistent Weird Shift Into Overdrive (4th) Only When In "D"
    thats a lot of good maint stuff there, old folks rule, they take care of their stuff to the end, well most of em.
    that 4 th gear hub, is a great upgrade too, the old ones strip out and you lose 4 th gear, so you look to be in good shape, id hold onto it. just continue to take care of it.
  1. "Perfect Shift" Indicator wont illuminate
    By Grand Prix1 in forum General Tech Discussion
    Last Post: 10-21-2011, 08:03 AM
  2. Occasional shift "clunk" and uneasy acceleration
    By nik12937 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-06-2011, 03:49 PM
  3. Replies: 15
    Last Post: 09-04-2011, 05:25 PM
  4. Weird "creaking?" noise from dash
    By NovoGTP in forum General Tech Discussion
    Last Post: 05-06-2011, 02:04 PM
  5. Feedback/Opinions on the Intense "Shift Kit"?
    By Going Too Phast in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-30-2008, 10:10 PM
