As you may have seen in my earlier post the transmission has died in my son’s car. We had just recently completed a 2001 GTP L67 SC engine, PCM, and (recently GM Remanufactured) HD trans swap replacing his old 2000 GT L36 engine, PCM, and trans. We did this when the intake gasket leaked and ruined the motor at around 72k miles.
We still have the original transmission (the non HD version) that came out of his car so I am considering swapping it back into the car. I know that we will need to have the PCM tuned for this swap but what other problems would we run into? IE what should I expect regarding the different gear ratios when I pair the old GT trans with the L67 engine and Torque converter?
Also assuming the HD differential is OK in the GTP trans I think I will pull it out and drop it into the GT trans. Is this a good Idea or more work than it is worth?
If it looks ok can I use the old torque converter that came with the GTP unit or am I asking for trouble?
Here is a new update on the trans I want to put back in the car
The original GT trans was running good before we swapped it but when we dropped the pan we saw about 4 small metal shavings in the filter and two more in the bottom of the pan. They don’t look like much and when I drug a magnet through the fluid I didn’t pick up much at all other than these chips? The fluid smells good and after sitting overnight there is just a little non ferrous sludge in the bottom. Should I be worried about this or not?
Thanks for any help guys.
