#81
Re: **HELP** 04 GTP SC shifts but wont drive
wstefan20
Agreed! The only "special" tools I use on my rebuild are these:
Amazon.com: SST-0015 - Universal Lip Seal Installer / Remover Transmission Tool: Automotive
Amazon.com: Lubegard 19250 Dr. Tranny Assemblee Goo, Green, Firm Tack Lubricant, 16 oz.: Automotive
Amazon.com: Goplus Automatic Transmission Clutch Spring Compressor Removing / Installing Tool Kit: Home Improvement
The top tool is for the lip seals, it really isn't the best tool out there, but with some practice, it works well!
Second one is the lubricant you'll need so that it has some lubricant when you start it up for the first time. I've even shipped a trans halfway cross country and this stuff was still in place! You'll use trans fluid on some things and this on others. Rule of thumb, using more doesn't hurt anything.
Last tool again, isn't the best one out there, but it gets the job done. On the second clutch I had to cut the tabs off an old steel friction plate I had and use it to "even out" the pressure of the compressor so it doesn't bend the springs, and it doesn't reach one of the clutches, but I have a shop press so I put the top of this tool in it and it worked. you have to get creative unless you want to spend lots of money on a high end spring compressor.
100% hands down, this is the best video tutorial and manual I used (and still use):
STOCK DVD VIDEO TRANSMISSION REBUILD OVERHAUL MANUAL 4T65E 4T60-E 4T60E TRANS | eBay
You can honestly do a rebuild first time in a day or two using this manual, it's that comprehensive and easy to follow.
Other than that, we're here for any questions or help you might need! If you don't think you can tackle it, I've got a core I'd rebuild if you wanted to make the drive? lol
California to Missouri...... Uuuuum, I'll pass haha..
This is beyond the best information I've gotten ha.. I seen theres a HP DVD, will I need that one because I'm working with a 4T65E-HD?
So I'll have to purchase a Full Rebuild Kit and a Shift kit as well?
Sent from my SM-N950U using Tapatalk
#82
04-15-2018
showtastiik
Lol yeah I've made the drive twice. Not fun... haha
and the dvd set is for both. The only difference between your "hd" and regular is the differential and number of gear teeth, noting special. The hd on the dvd manual is referring to high horsepower builds which is a good video to have if you're going that route, butyou would need both dvds.
What you'll look for is a master rebuild kit with new lip seals and pistons. I recommend replacing the bands while you're there, get all the electronic solenoids and such, new torque converter, filter, shift kit, and that's about it. One thing common to our transmissions but commonly overlooked is the afl valve in the channel plate (sonnax and other brands make a fix) and the boost valve. I'm a big fan of the sonnax sure cure kit if you can stomach the price. Basically, there's no kit that 100% has everything you need. I'll try to post some kits I recommend
Post Thanks / Like - 1 Thanks, 1 Likes, 0 Dislikes
#83
Ok, sweet!.. I've been doing some research myself and theres nothing like knowing exactly what you're looking at. I'm taking major notes from you. Please do send what you recommend. Appreciate it all! Thanks.
#84
wstefan20
Also, if you can chime in on this choice. I know it can be an unknown and I do have a 13month warranty on my yard granny. But, since I'm going this route on a dirty rebuild. Which Tranny should I choose. Blind educated guess by just looking at the filters.
#85
04-16-2018
The yard tranny for sure. That way you can return it and still get another.
I found that in order to do the 1st/3rd clutches I had to extend the tool
BillBoost37
Gotcha!.. Was this a tool you made or purchased?
#87
04-16-2018
In the links to stuff WSTE posted, it's the third link. I bought the bottom threaded nut/etc from tractor supply in order to make the tool long enough to use. I'm interested to hear how he found it long enough for that hub.
Post Thanks / Like - 0 Thanks, 1 Likes, 0 Dislikes
#88
04-16-2018
BillBoost37
You're 100% right bill! I ended up using this tool in my shop press and basically just used the press to push the tool down rather than deal with the threads, and that works for me, but now that I look at your extension, I think that would be a much easier way! Luckily the snap ring and compression on that clutch spring is pretty low from what I remember so it's not that bad either way. I would say to try Bill's extension method first though because it's probably vastly easier to grab the snap ring without the press being in your way.
As far as the kits, this is the kit I've used a few times: https://www.ebay.com/itm/4T65E-2004-On-GM-Tap-Shift-Super-Master-Rebuild-Kit-With-Pawl-Lug-Input-Friction/272494991653?epid=672397377&hash=item3f71f79925:g: 5lAAAOSwNSxVCzs8&vxp=mtr
Along with: 4T65E Transmission Solenoid Kit Set TCC, 2 Shift, EPC, Switch 2003 UP 84420AK | eBay
I also recommend at the bare minimum for the valve body: GM 4T65E Transmission AFL Valve Repair Kit | P1811 Code Stopper | SUPERIOR K098 | eBay
If you really want to future proof your rebuild, I'd get this instead of the above afl repair: Sonnax SC4T65E Transmission . 4t65e 91-99 | eBay
The last link includes the lube tube retainer along with seletable shims for the thrust clearances. A lot of rebuilders neglect to check this movement, but it is discussed in the video manual I cited.
These are what I use in all my rebuilds partly because I like to fix it once and fix it well rather than doing it again in a few years, and partly because I'm ocd. Take it as you will. Personally, I don't think $500 is unreasonable for parts cost to get a transmission that will likely outlast the car.
One note, while not always necessary to change, the kit does come with the case bushings and such that need to be pressed in. I got lucky and used various sockets with my shop press to install them and it worked, but it may not always work like that. I'd check them and if you can't catch your fingernail on them, you're probably good to go.
The one bearing I highly recommend replacing is: Amazon.com: AC Delco 75086 BR Needle Bearing, Converter: Automotive
As this bearing is known to grenade with age. It is press fit, so removing and installing will require a press, but most shops don't mind doing this for you for a small fee.
I usually clean and reuse the other needle bearings. The video goes over how to properly clean and inspect the bearings.
Sorry for the long description, but hopefully that helps!
#89
wstefan20
Along with:
This is exactly what I needed. Very detailed. Love it! Pretty much covers everything. I just have to get the right tools for the job and see if I can get some help with the parts you mentioned, that I might need a press for. All I'll need is a torque converter maybe?
Time to execute now. Thanks!
#90
04-16-2018
showtastiik
Thanks! And you didn't hear me say this, but in a pinch, I've used different sized sockets and a soft mallet to install and a very very steady hand with a dremmel tool and cutoff wheel to cut almost all the way through the bearing then use a very carefully placed small chisel to "deform" the bearing and force it out. Now, I'm not saying this is the right way to do it, but it works as long as you're careful!
And sorry I forgot to mention the torque converter. Yes, I 100% recommend replacing the torque converter. It is made of woven carbon and tends to hold a lot of "nasties" and isn't rebuildable, so often if you re-use one, it'll dump crud and clog up the channel plate filter and cause it to burn up pretty quick. Not worth trying to save money on it.
#91
wstefan20
Haha thanks. I'll keep that in mind when the time comes and I'm desperate. A lot of good info here. Love it!
#92
04-17-2018
WSTE.. It's not perfect. Actually I usually had to space something on the end of the 1st/3rd hub in order to use that piece as an extension. But everyone had a drive or driven gear hanging out when they are building a trans lol.
Any suggestions on torque converters? I'm now shopping around for one.
With my CNC ported heads, I might be looking into either, just 1.9 rockerarms or just grabbing a Camshaft since my old trans have to come out.
I'm looking forward to showing off all parts in this thread once I start taking both the yard and my Trans apart. Educate others. Especially with my issues, with only sometines D,R,1,2&3 not working. Cant forget a little grinding noise on acceleration. From my research and how my filter looks, I'm hoping to find the overdrive clutch hub to be stripped. Thinking that's where the metal is coming from. But all in all, I cant wait to show and tell what went mostly went wrong in my Trans. On the otherside, the yard Trans will definitely be a "What the hell happen" as well. I'm not sure how many ppl online cut open their filters on failed Transmissions but they'll definitely get an idea once I fully open up both.
#94
04-17-2018
showtastiik
Great thinking! Definitely easier to swap a cam with the trans out of there.
As far as torque converters, unless you're going all out with a custom built torque converter, I just recommend the usual brands. I think I went with proking since they were cheap at the time. Haven't had any issues with them so far.
I'm glad you're taking the time to document the process! I meant to, but my first transmission broke right after I rebuilt the engine and I wanted to get it back on the road asap. I'll probably be upgrading some internals this summer so I'll definitely have to document mine as well! Can't wait to see the thread anyhow, and hope you have as much fun as I did rebuilding it! They're not for the faint of heart, but I do think people give them a bad wrap as being overly complex to service.
#95
wstefan20
Yeah, maybe someone out there will be as confident as I am for the first time. Let me remind everyone, I'm only 2 months in on modding and only did my topside of the engine for the first time a month ago..... Correct the mistakes I make. But with the help of you guys, I think I'll be alright but you still never know haha. It's always something....
#96
04-19-2018
Brandon did a great write up IIRC.
The absolute needed items I found were the teflon seal resizer sleeve, that clutch tool and the engine stand with trans bracket. I made my own bracket after seeing pictures. Being able to put this trans tail down was extremely helpful to me during reassembly since I didn't have all the correct tools. Don't get discouraged when putting the 3rd sprag into the clutches, I like to use two small screwdrivers or picks to line up the clutches as well as possible.
#97
04-19-2018
BillBoost37
Shoot thanks bill! So I got a trick an old mechanic taught me. Grab a small funnel that lightly tapers, use a heat gun to warm the teflon and push up the funnel lubricated with trans fluid to stretch the seal. Then take some thin plastic sheet (I used an old cut up coke liter cut to square) then roll it up and lubricate with trans fluid. Wrap around the shaft where the seal goes and slip it right into the grove. Now wrap that same sheet around the seals and place a hose clamp around each seal and leave for half an hour. Then enjoy the fact you didn't have to spend on that tool!
Oh, and Bill pointed out an error I made earlier. I was confused and thinking the engine was also coming out of the car, then swapping the cam is easy. ButI don't see doing this with the engine in and trans out. I'd be better to wait till the trans is in and drop the side subframe method. Still not my favorite option, but it works
#98
I can't car too good.
04-19-2018
BillBoost37
Do you have a link by chance?
Also @ OP, I helped you get the part number for that broken cap from fb. lol
#99
BillBoost37
Hey BillBoost, can you send me a link from Tractor Supply of what threaded nut/etc you bought. I'm getting ready to make all my purchases for the rebuild now. Thanks!
Post Thanks / Like - 0 Thanks, 0 Likes, 1 Dislikes
#100
BillBoost37
Also how does the "Teflon Seal Resizer Sleeve" and the "Engine Stand With Trans Bracket" look like? Any links or picks?
