Thread: **HELP** 04 GTP SC shifts but wont drive
Results 1 to 20 of 113
  1. #1 Re: **HELP** 04 GTP SC shifts but wont drive
    Brandon did a great write up IIRC.
    The absolute needed items I found were the teflon seal resizer sleeve, that clutch tool and the engine stand with trans bracket. I made my own bracket after seeing pictures. Being able to put this trans tail down was extremely helpful to me during reassembly since I didn't have all the correct tools. Don't get discouraged when putting the 3rd sprag into the clutches, I like to use two small screwdrivers or picks to line up the clutches as well as possible.
  2. #2 Re: **HELP** 04 GTP SC shifts but wont drive
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Shoot thanks bill! So I got a trick an old mechanic taught me. Grab a small funnel that lightly tapers, use a heat gun to warm the teflon and push up the funnel lubricated with trans fluid to stretch the seal. Then take some thin plastic sheet (I used an old cut up coke liter cut to square) then roll it up and lubricate with trans fluid. Wrap around the shaft where the seal goes and slip it right into the grove. Now wrap that same sheet around the seals and place a hose clamp around each seal and leave for half an hour. Then enjoy the fact you didn't have to spend on that tool!
    Oh, and Bill pointed out an error I made earlier. I was confused and thinking the engine was also coming out of the car, then swapping the cam is easy. ButI don't see doing this with the engine in and trans out. I'd be better to wait till the trans is in and drop the side subframe method. Still not my favorite option, but it works
  3. #3 Re: **HELP** 04 GTP SC shifts but wont drive
    Jan 2018
    US
    Quote Originally Posted by wstefan20 View Post
    So if I skip installing the Cam, you'll recommend me to keep the engine in, drop subframe yo take original Trans out, rebuild the yard Trans and than install it while engine is in from under the car?
    Sent from my SM-N950U using Tapatalk
  4. #4 Re: **HELP** 04 GTP SC shifts but wont drive
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    Do you have a link by chance?
    Also @ OP, I helped you get the part number for that broken cap from fb. lol
  5. #5 Re: **HELP** 04 GTP SC shifts but wont drive
    Jan 2018
    US
    Also how does the "Teflon Seal Resizer Sleeve" and the "Engine Stand With Trans Bracket" look like? Any links or picks?
  1. all wheel drive drive rain with 3.8 engine
    By fisheson in forum General Grand Prix Discussion
    Last Post: 03-11-2016, 12:13 PM
  2. GXP clunk from park to drive, drive to reverse..
    By sasquatch094 in forum General Tech Discussion
    Last Post: 02-13-2014, 04:27 PM
  3. Drive side door wont unlock
    By ffbwizard in forum General W body
    Last Post: 01-02-2014, 01:41 PM
  4. Wont upshift 2-3 but down shifts 4-3
    By bstuby in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-03-2011, 08:40 AM
  5. 1998 gtp wont drive in 4th NO SLIPPING THO
    By beno420 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-21-2011, 11:23 PM
