#1
Dash Guages shets off randomly
Was wonder if anybody know specifically what this problem can be.... Goes shets off and I'll have to turn the car off and on to make it work again
Sent from my SM-N950U using Tapatalk
#2
Re: Dash Guages shets off randomly
Post Thanks / Like - 0 Thanks, 1 Likes, 0 Dislikes
#3
selliott
Relay overheating?
Overheating, hhmmm, Okaay!. Overheating "Relay" to the--> ".............." what though?
#4
I had a bad ground from the negative battery cable to the frame just below the battery/fuse panel. It caused all sorts of weird electrical issues with things randomly not working, gauges turning on and off, alt. voltage low, etc. Check your grounds.
04 GP GT- top swap, VS cam, 2.8 pulley, E85, headers, 60 injectors, TEP 3:29 trans, Racelogic Traction Control, ZZP dyno tuned.
Post Thanks / Like - 1 Thanks, 1 Likes, 0 Dislikes
#5
Do you have a after market radio?
#6
98grand
Yes, I certainly do. Pioneer to be exact.. That can lead to this problem? If so, I need to know asap ha. Getting irritating watching my dash gauges go of mid trip to wherever I go. Appreciate the advice as well!
#7
I also have pioneer radio too if you have the box that controls the steering controls disconnect it. And see if it stops shutting off the gauges. This is what was happening with my car took that out and just had radio connected without steering controls for over a year now and it has never happened again.
#8
I have the same problem once in a while. When the gauges shut off the red light on my rear view mirror goes on and the dic reads low fuel. Bonus is I noticed mileage does not get logged. I'm not too worried about it.
'97 Grand Prix GT Coupe
'05 Grand Prix GTP Sport Red Metalic SOLD
'05 Grand Prix GTP Silver
#9
GYSOT1
Yeah, I feel ya on that note. Need to get to the bottom of this though. Definitely need to know what's going on most of the time, not all haha. About to open up everything this weekend to figure this out
#10
I break stuff
12-05-2018
Are you running hids and or alternator voltage booster?
#11
selliott
Not running hid's but I do have an alternator voltage booster... Haven't had a chance to crack open my dic. Might also be the Steering Wheel Control Interface I heard. Maybe if I get that connected I wont have to worry about weird signals throwing everything off
#12
I break stuff
12-08-2018
I would get rid of the voltage booster immediately, had one in mine and it ended up failing and burning up stuff.
#13
selliott
Sheesh! Really, I had it for about a yr. Probably need too now.
#14
I break stuff
12-10-2018
showtastiik
I won't ever mess with one again. I started having all sorts of electrical issues, wiries overheating, amps going into safety etc. Once it was removed the issues stopped.
#15
Donating Users
12-11-2018
selliott
This. I had one for a few months and it took out my battery.
Chris B
2009 CX-9
** SOLD ** 2002 GT
