Thread: **HELP** 04 GTP SC shifts but wont drive
Results 1 to 20 of 113
  1. #1 Re: **HELP** 04 GTP SC shifts but wont drive
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Quote Originally Posted by showtastiik View Post
    California to Missouri...... Uuuuum, I'll pass haha..
    This is beyond the best information I've gotten ha.. I seen theres a HP DVD, will I need that one because I'm working with a 4T65E-HD?
    So I'll have to purchase a Full Rebuild Kit and a Shift kit as well?
    Sent from my SM-N950U using Tapatalk
    Lol yeah I've made the drive twice. Not fun... haha
    and the dvd set is for both. The only difference between your "hd" and regular is the differential and number of gear teeth, noting special. The hd on the dvd manual is referring to high horsepower builds which is a good video to have if you're going that route, butyou would need both dvds.
    What you'll look for is a master rebuild kit with new lip seals and pistons. I recommend replacing the bands while you're there, get all the electronic solenoids and such, new torque converter, filter, shift kit, and that's about it. One thing common to our transmissions but commonly overlooked is the afl valve in the channel plate (sonnax and other brands make a fix) and the boost valve. I'm a big fan of the sonnax sure cure kit if you can stomach the price. Basically, there's no kit that 100% has everything you need. I'll try to post some kits I recommend
  2. #2 Re: **HELP** 04 GTP SC shifts but wont drive
    Jan 2018
    US
    Quote Originally Posted by wstefan20 View Post
    Also, if you can chime in on this choice. I know it can be an unknown and I do have a 13month warranty on my yard granny. But, since I'm going this route on a dirty rebuild. Which Tranny should I choose. Blind educated guess by just looking at the filters.
  1. all wheel drive drive rain with 3.8 engine
    By fisheson in forum General Grand Prix Discussion
    Last Post: 03-11-2016, 12:13 PM
  2. GXP clunk from park to drive, drive to reverse..
    By sasquatch094 in forum General Tech Discussion
    Last Post: 02-13-2014, 04:27 PM
  3. Drive side door wont unlock
    By ffbwizard in forum General W body
    Last Post: 01-02-2014, 01:41 PM
  4. Wont upshift 2-3 but down shifts 4-3
    By bstuby in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-03-2011, 08:40 AM
  5. 1998 gtp wont drive in 4th NO SLIPPING THO
    By beno420 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-21-2011, 11:23 PM
