Thread: ....you know what it is... 700whp build
Page 4 of 14 FirstFirst ... 23456 ... LastLast
Results 61 to 80 of 274
  1. #61 Re: ....you know what it is... 700whp build
    Donating Users Dboy23's Avatar
    Aug 2008
    Michigan
    Quote Originally Posted by rocafella2032 View Post
    I don't understand a word in this thread but I love it.
    x2 subscribed
    *sig is too tall*
  2. #62 Re: ....you know what it is... 700whp build
    Jan 1970
    Maquoketa, Iowa
    I just want to see a build list or some pics, I like the ideas and respect the amount of work your putting into these cars, but all your listing is some HP numbers and a few short vids that don't tell us anything. I would like to see what fuel system your using, what works/what didn't work or what's limiting you. If you described a bit more it wouldn't seem so unreasonable numbers you're putting up.
  3. #63 Re: ....you know what it is... 700whp build
    GT Level Member kuntzie's Avatar
    Feb 2010
    Kitchener, Ontario, Canada
    heads are on! mls and arp's for the ported CCH heads
    02 Grand Prix GT Intercooled turbo 5-speed 718whp 618wtq @ 21psi 7575 billet, spool valve, custom manifolds, 4" downpipe, 16way adjustable coilovers, 18x9.5 with 275's all around, gxp interior, gxp brakes
    tilton triple disc, custom aluminum flywheel, tilton slave and master, an awful lot more
  4. #64 Re: ....you know what it is... 700whp build
    Willoughby, Ohio
  5. #65 Re: ....you know what it is... 700whp build
    Feb 2010
    Quote Originally Posted by FoSHO99 View Post
    94 octane, alky injection (m10 nozzle) racetronix FP and rewire, 65# injectors, my IPW was at 20ms or about 97% duty cyle IIRC,the fuel pressure was not 100% keeping up, so im going dual pump i the tank this year most likely
    the cam is a 224 224 .574/.566 114lsa, it broke my stock heads 2x's as well as broke a valve spring on 1 cylinder and cracked a intense pushrod
    i had a spec stage 3+ clutch, it slipped got to replacements, still slipped, went stage 4, it slipped right away aswell.
    went with bully and it held for the most part until about 6300rpms so thats why i went triple disc
    the car was running a 3" dp and cutout that freed up 60+whp, aswell as a custom rear manifold, front power log that cracked manyof times,
    intake runners wer removed and had an hv3 at the dyno tme,
    FWIW i did 403whp on 1.9s and a 2.5" downpipe on 18psi, so my numbers arent to different then an automatic,
    i also own a 04 comp g tha dynoes 581whp auto (with the heads i just put on) and a larger intercooler,, aswell as the 3" downpipe,
    the car isnt near as fast as my 5-speed but can launch better, but 1/4 mile would be about the same IMHO, high 10s on a decent day
  6. #66 Re: ....you know what it is... 700whp build
    damn...you break stuff lol keep it up im waiting for the new #'s
  7. #67 Re: ....you know what it is... 700whp build
    Feb 2010
    it took out one engine becuase all the oil shot out the head when it broke, ya stuff breaks, but i only ever had 1 trans failure, and i didnt put the passengeside braket attaching the trans to the engine, it didnt even last 2 days like that, so ya my mistake
  8. #68 Re: ....you know what it is... 700whp build
    Topeka, KS
    Just saw this thread.... INTERESTING
  9. #69 Re: ....you know what it is... 700whp build
    Feb 2010
    the car barely has the equlivent of 70k miles on it and is on its 6th trans, 4th engine, +++ and had 8 different clutches installed in under 1k miles , the car is a slut to say the least
  10. #70 Re: ....you know what it is... 700whp build
    im just throwing this out there ,,,my guess is its not a daily driver lol
    seems like the guys at the track see you coming and have the mops at the ready.
  11. #71 Re: ....you know what it is... 700whp build
    Feb 2010
    i DD this in the summer months, the car only had 1 issue last year and that was with the one head, other then that (and the trans cracking before putting it away) it was fine,
  12. #72 Re: ....you know what it is... 700whp build
    not to pry into your finances, but what this set up worth without all the stuff you broke already and how street able is it? like the current set up? sounds like a blast to drive around in.
  13. #73 Re: ....you know what it is... 700whp build
    Feb 2010
    i did the 5-speed swap in my driveway, costed me sub 1200 bucks, the car i bought cheap, turboed, i actually got in an accident with my lumina ltz that was turboed got 2500 cash for the damage, bought a montana and put the engine/ turbo setup into that, blew that transmission and sold the turbo kit for 2500,bought my 01 with 60k on it for 3k bucks turboed with a bad tcc selonid on its 2nd trans,
    was about to change the trans and blew it up,shattered the input shaft, put another auto in that came with the car and it lasted 2 weeks soi said f-it nddi i hw it should have been done
    also on a side note, i blew the auto in my lumina when it was turboed once aswell, so me and autos dont get along with power at all, i abuse them and the 5-speed takes it like a champ where the auto cant, even built
  14. #74 Re: ....you know what it is... 700whp build
    Feb 2010
    now:
    the heads are worth $2200, clutch $3k, cam, $220 springs, headgaskets $200, 7k km l26 $600 (good deal i got), turbo kit is going to be in the 4k range in mateials alone, but i may use this other kit i have from the 04 with upgraed piping/ intercooler/ dp all custom 1 off stuff.
  15. #75 Re: ....you know what it is... 700whp build
    thats not totally out of reach. im looking to build a fast toy as you can see by now.
    are you running a stock short block or do you got goodies in the lower end?
    10 large to spank everyone not to bad lol
  16. #76 Re: ....you know what it is... 700whp build
    Feb 2010
    stock, i reved to 7k last year on the larger turbo (didnt dyno with the larger .ar turbo .69 on dyno, .96 afterwards)
  17. #77 Re: ....you know what it is... 700whp build
    Topeka, KS
    I'd like to have some of you guy's bankrolls. Fvck. My car will never be fast
  18. #78 Re: ....you know what it is... 700whp build
    Feb 2010
    Quote Originally Posted by t24moore View Post
    Has nothing to do with hating. It has to do with the truth. Manual numbers are inflated plain and simple. Too bad most people on this forum doesnt understand that. But I guess if it is good enough for the supra crowd then its good enough for us. I do hope you succeed in your build, and hopefully that clutch holds because that would be a great benefit to the fiero world. But to boast about a 700 whp build with inflated numbers is plain asinine.
    well as mentioned i own a auto car that is not as fast after 50k and 581whp, so my "over inflated 584 whp" is whatever you think, but ill tell you right now, i drove the comp g for a wek(581whp) and i got bored with it.
    so to summerize:
    i had 584 manual, going for more
    i have 581 auto, its not really fun,not bad but meh, id have more fun with 400whp manual and it would be just as quick from a roll it--- but still made awsome "non inflated" numbers so think what you want to think
  19. #79 Re: ....you know what it is... 700whp build
    trust me if i do a build like this it will be towed to the track!!! that way if it blows up im not stuck there, and im going with a auto trans, so i may not want the same hp numbers you got there but at least i now know what it would take, thanks.
    so the 581 hp is working in a automatic still? it that one a turbo too?
    thats more than enough hp for me.
  20. #80 Re: ....you know what it is... 700whp build
    Feb 2010
    3rd gear doesnt really hold to well, i bought the car to part it out, but there is fixes for it to hold now.
  1. ZZP XPZ Build
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2017, 09:40 PM
  2. New build.
    By TheOtherNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2010, 05:44 PM
  3. $400 gtp build
    By heavyRfoot in forum General Tech Discussion
    Last Post: 03-13-2010, 01:29 AM
  4. New Build
    By kfish in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-16-2010, 08:50 AM
  5. The Build...?
    By Thunderturd in forum Off Topic Discussion
    Last Post: 11-04-2009, 07:35 PM
