Thread: ....you know what it is... 700whp build
Results 1 to 20 of 274
  1. #1 Re: ....you know what it is... 700whp build
    GT Level Member kuntzie's Avatar
    Feb 2010
    Kitchener, Ontario, Canada
    Quote Originally Posted by FoSHO99 View Post
    I just want to see a build list or some pics, I like the ideas and respect the amount of work your putting into these cars, but all your listing is some HP numbers and a few short vids that don't tell us anything. I would like to see what fuel system your using, what works/what didn't work or what's limiting you. If you described a bit more it wouldn't seem so unreasonable numbers you're putting up.
    94 octane, alky injection (m10 nozzle) racetronix FP and rewire, 65# injectors, my IPW was at 20ms or about 97% duty cyle IIRC,the fuel pressure was not 100% keeping up, so im going dual pump i the tank this year most likely
    the cam is a 224 224 .574/.566 114lsa, it broke my stock heads 2x's as well as broke a valve spring on 1 cylinder and cracked a intense pushrod
    i had a spec stage 3+ clutch, it slipped got to replacements, still slipped, went stage 4, it slipped right away aswell.
    went with bully and it held for the most part until about 6300rpms so thats why i went triple disc
    the car was running a 3" dp and cutout that freed up 60+whp, aswell as a custom rear manifold, front power log that cracked manyof times,
    intake runners wer removed and had an hv3 at the dyno tme,
    FWIW i did 403whp on 1.9s and a 2.5" downpipe on 18psi, so my numbers arent to different then an automatic,
    i also own a 04 comp g tha dynoes 581whp auto (with the heads i just put on) and a larger intercooler,, aswell as the 3" downpipe,
    the car isnt near as fast as my 5-speed but can launch better, but 1/4 mile would be about the same IMHO, high 10s on a decent day
    02 Grand Prix GT Intercooled turbo 5-speed 718whp 618wtq @ 21psi 7575 billet, spool valve, custom manifolds, 4" downpipe, 16way adjustable coilovers, 18x9.5 with 275's all around, gxp interior, gxp brakes
    tilton triple disc, custom aluminum flywheel, tilton slave and master, an awful lot more
  2. #2 Re: ....you know what it is... 700whp build
    damn...you break stuff lol keep it up im waiting for the new #'s
  1. ZZP XPZ Build
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2017, 09:40 PM
  2. New build.
    By TheOtherNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2010, 05:44 PM
  3. $400 gtp build
    By heavyRfoot in forum General Tech Discussion
    Last Post: 03-13-2010, 01:29 AM
  4. New Build
    By kfish in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-16-2010, 08:50 AM
  5. The Build...?
    By Thunderturd in forum Off Topic Discussion
    Last Post: 11-04-2009, 07:35 PM
