Thread: ....you know what it is... 700whp build
Page 6 of 14 FirstFirst ... 45678 ... LastLast
Results 101 to 120 of 274
  1. #101 Re: ....you know what it is... 700whp build
    GTX Level Member Confusingboat's Avatar
    Minnesota
    Why? It's a legit point.
    Rambling products and numbers is cool...when you were in high school. I'd bet 20 to 1 this "700 WHEEL HP Manual Trans" WBody never sees 10's...and if it does...it'll be 10.99999 @ a billion mph.
    Why make all this power when you can't even use it? Sub 500 WHP Auto WBody's are cracking off low 11 high 10 second passes with half the stuff your using...so...your build is moot?
    Time for AWD conversion? LOL
    2004 Grand Prix GT2 - SOLD
    2015 Evo MR
  2. #102 Re: ....you know what it is... 700whp build
    GTX Level Member real diehl's Avatar
    Salina, KS
    So what does the current setup make powerwise?
    signature removed for inappropriate content.
    -bio
  3. #103 Re: ....you know what it is... 700whp build
    Quote Originally Posted by realdiehl View Post
    01 Grand Prix GT Intercooled turbo 5-speed 583whp 551wtq@ 19.5psi bagged, among many many other mods
  4. #104 Re: ....you know what it is... 700whp build
    Salina, KS
    The sig picture says otherwise...just wondered.
    -bio
  5. #105 Re: ....you know what it is... 700whp build
    GT Level Member kuntzie's Avatar
    Feb 2010
    Kitchener, Ontario, Canada
    Non updated sig pic.. That was 1.9s and hv3 with turbo
    02 Grand Prix GT Intercooled turbo 5-speed 718whp 618wtq @ 21psi 7575 billet, spool valve, custom manifolds, 4" downpipe, 16way adjustable coilovers, 18x9.5 with 275's all around, gxp interior, gxp brakes
    tilton triple disc, custom aluminum flywheel, tilton slave and master, an awful lot more
  6. #106 Re: ....you know what it is... 700whp build
    GT Level Member t24moore's Avatar
    Feb 2008
    Houston
    You've done nothing but hate on this and for no reason. Speaking of learning, you're a great example of how to be totally ignorant.
    LOL Go and search any of my other posts. All I do is help people when I come here. Im ignorant for disagreeing with someone about thier setup? Call it what you want, but people should know the truth instead of drooling all over his balls like you all seem to like to do. Thats why he posts this garbage here. And what am I exactly jealous of? I have a pretty beefy ass setup myself if you didnt read my sig. This guy comes here so you all can stroke his ego, sad part about it is that some of you are fighting harder than he is. Im done with this thread. Good luck on your build kuntzie.
    Comp Turbo 6765 T4-ST5-A2A IC-Ported Heads-Custom Turbo headers-80 lb inj-F-Body UIM and LIM-AEM WB, TEP trans w 1" chain and Circle D TC, Dual 255s, Bilstien Struts
    WHY IS EVERYONE SO OPPOSED TO DOING A COMPRESSION TEST TO TROUBLESHOOT PROBLEMS?
  7. #107 Re: ....you know what it is... 700whp build
    the car could make 300whp and i'd still like it.
    the bags. the wheels. the 5 speed. it's all something i'd want on this platform that i can't have. so it's easier to make big dyno numbers with a manual, who cares?
  8. #108 Re: ....you know what it is... 700whp build
    Feb 2010
    t24, id really like you to drive my car, its something you cant really describe, even at 400whp it was more fun then any automatic fwd car ive ever drive, the rowing through the gears just makes things intresting,
    fwiw.
    the civics, fwd talons, srt4s have seen 8s, 9s, on manual transmissions, sure the hp needed is higher, but the numbers arent over inflated by a crazy number, like 10% max so 700whp, ok 630whp on an auto .... but yes my 700whp manual will get beat in most cases by a 500whp auto grand prix
  9. #109 Re: ....you know what it is... 700whp build
    Feb 2009
    flintnasty MI
    And having owned a 500whp grand prix, I can tell you that it would have taken STUPID amounts of work to get it from a 11.7 second car to a 10.99.
  10. #110 Re: ....you know what it is... 700whp build
    GT Level Member fremmy182's Avatar
    Center Moriches, New York
    thats awesome you made it 5 speed, was it alot of money to do, and i didnt even know it was possible
  11. #111 Re: ....you know what it is... 700whp build
    North Jersey
    another one subscribed right here
  12. #112 Re: ....you know what it is... 700whp build
    Feb 2010
    tilton 1.44" high release bearing for the most clearance i could make.
    new flywheel to accomidate that weighs under 10lbs, the clutch pedal travel is only about 3/8", its like an on /off switch.
    the clutch is steped and the back side is rounded,
    the guys from tiltion (where the clutch and release bearing are from) are excited about my build and want pictures of the installiation and such.
    i had to get a centric sleve for the release bearing to sit on the input shaft, and the braided clutch lines, that will both be done tomorrow and then the assembly will begin this week, i hope to have the engine in by the end of the week.
  13. #113 Re: ....you know what it is... 700whp build
    Waukesha, WI
    piece of art man
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  14. #114 Re: ....you know what it is... 700whp build
    Feb 2010
    i also ordered new personalized plates for the car
  15. #115 Re: ....you know what it is... 700whp build
    GT Level Member Wrongwayislost77's Avatar
    Arvada, Colorado
    "Do not stroke the pedal..."
    Bwahahahaha.
    Sorry; sub'd.
    Sig2
    30%, 5000k's, GMPP/Addco Sways, BMR Braces/Arms, FE3 Struts, WBS Springs, 12" w/ SS Lines & F-Bodies. Wiz, HVTB, HV3, CPlog, Shift Kit, ZZP 1.0, Alt/Volt Boost, Etc.
  16. #116 Re: ....you know what it is... 700whp build
    Feb 2010
    clutch on, flywheel on, release bearing ready for my braided lines to come in, safe to say im the only 284 with a push style clutch,
    look how tight those clearances are in there! so much measuring and number crunching to make it all fit,
    rundown:
    custom made flywheel locally, tilton triple disc clutchs in sintered metallic, tiltion 1.44" height 8000 series slave cylinder (459$ :S) -3AN fittings and stainless braided teflon lines, the master is stock with a braised -3 fitting on it aswell so no plastic or rubber lines
    also, this trans has under 55k miles on it, so clean!
  17. #117 Re: ....you know what it is... 700whp build
    PTFE lines are kinda sorta plastic related?
    props for sintered disc and short clutch travel.... good luck DD'ing it
  18. #118 Re: ....you know what it is... 700whp build
    Feb 2010
    i think it will be fun to dd forsure lol
  19. #119 Re: ....you know what it is... 700whp build
    Feb 2008
    Quote Originally Posted by kuntzie View Post
    Why does it look like someone took a bite out of the top of this picture??
  20. #120 Re: ....you know what it is... 700whp build
    Waukesha, WI
    a rag sitting on the motor?
    RayRay
    92 Turbo miata
    02 lexus is300
  1. ZZP XPZ Build
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2017, 09:40 PM
  2. New build.
    By TheOtherNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2010, 05:44 PM
  3. $400 gtp build
    By heavyRfoot in forum General Tech Discussion
    Last Post: 03-13-2010, 01:29 AM
  4. New Build
    By kfish in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-16-2010, 08:50 AM
  5. The Build...?
    By Thunderturd in forum Off Topic Discussion
    Last Post: 11-04-2009, 07:35 PM
