Thread: Injector flow rate OR Cylinder gain?
Results 1 to 20 of 32
  1. #1 Re: Injector flow rate OR Cylinder gain?
    Mar 2014
    Tucson
    Well... Will you look at that! Guess I hadn't even opened the scanner yet. I've only played in the editor. Looks like I need to go for a drive now.
    Edit:
    After a good night sleep, and a little more reading, it's making more sense. I created a custom histogram to log LTFT on the MAF table in the scanner per the sticky at the top of the page.
    Here's my plan:
    1.) Change target stoich to 9.85
    2.) Zero out the HOT PE table
    3.) Connect laptop and Flash PCM
    4.) In "VCM" controls, Turn close loop OFF and reset fuel trims
    5.) Start the car, click "start scanning" and go for a drive.
    Then go from there...
  1. Anyone know the going rate on a mp112?
    By SomeDudeAtHome in forum General Tech Discussion
    Last Post: 08-08-2013, 05:31 PM
  2. Compression Rate
    By Bigheadedon in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-04-2013, 09:32 AM
  3. Regal GS Spring Rate vs 40th Anniversary Spring Rate
    By 40th in forum Brakes/Suspension/Chassis
    Last Post: 04-09-2011, 10:57 AM
  4. From misfire at cylinder 3 to a open circuit on the fuel injecter at cylinder 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 07:49 PM
  5. Coding cylinder 3 missfire and cylinder 3 injector port open
    By MATHEWSMAN1969 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-20-2010, 04:27 PM
